Question about Microwave Ovens
Aluminum Foil cooked in microwave. Is the unit safe to operate?
My daughter placed five potatoes wrapped in aluminum foil in our Jenn Air microwave for approx. 28 minutes. Obviously the potatoes weren't cooking. The digital readout ceased working, and the unit became inoperable. Within a few hours, the unit was back up. We have not used the unit since. I am under the impression that the unit is totaled, and unsafe to use. My question: is that correct? Is the unit now unsafe to operate? THANK YOU in advance for your help. Garry Watkins
  • pinch530 Apr 21, 2009
    If aluminum foil cooks inside a microwave oven for 28+ minutes, is that unit unsafe to use again? The unit became inoperable after the incident, now appears fine. Any danger in cooking food inside this unit? Thanx!
    Thank you! Your answer was very helpful, as well as the link you provided with further information.
    Awesome!
  • 15,935 Answers
Technically, if you do not allow the metal to touch the sides of the interior cabinet (causing bare metal in the ceramic) it will not cause a problem.
The JennAir has an auto shutdown function that activated when it detected the excess temperature inside the cabinet - instead of starting a fire :D
Once it cooled back down - the microwave will operate as normal.
Inspect the cabinet walls for bare metal - and use ceramic microwave repair kit to fix if necessary.
PLEASE SEE THIS LINK - it talks a bit on the safety of using foil in microwaves.
The unit is safe to operate - however - to test the proper operation of the microwave - insert a cup of water, and see if it boils in 2 minutes.
If the water fails to get warm - you have internal damage that will need servicing by a qualified repairperson - as there are potentially lethal amounts of stored energy inside that must be discharged properly before working on it.
Thanks for using FixYa!!
Posted on Apr 21, 2009
  • 547 Answers
Look for the fuse and change it as long as it was not fried it can still be used please rate me thank you for useing fixya
Posted on Apr 20, 2009
Can i use aluminium foil in convection mode in microwave
It is best to not use aluminum foil in a Microwave since microwaves cant go through it, so It will not heat properly. If you are using it only on Convection It is just fine, it is like using a regular over then. Same kind of issue though if you are using convection, that is to bathe the meat evenly in circulated air. If you cover it in aluminum you lose a little effectiveness of the convection on the food your cooking. If it is to stop splatter just make a small tent over it and maybe tooth pick it down. Letting the air flow get under it but not splatter the entire inside.
Aug 24, 2017 | Microwave Ovens
I put pizza wrapped in aluminum foil into the microwave for 3-5 seconds until i saw sparks.. i took it out and it left black marks on the microwave. How do i get it off? Does the microwave still work?
If you shut it down quick enough the microwave will be operational, to remove the black marks mix baking soda in water and until becomes a paste, apply over affected area's let it sit for 5 minutes and wipe off with clean warm water.
Jun 11, 2012 | Tappan Microwave Ovens
The paint came off because my grandaughter put aluminum foil in it. How can I repair the paint?
I would like to make a warning ,do not try to repair microwaves , they are lethal weapons , I know someone who ran one with the cover removed and cooked his kidneys , if it is faulty dispose and get new, if aluminium foil was put inside it has heated up and as you say damaged paint ,the seal could also be damaged and lethal , dispose and buy another .
Mar 22, 2012 | Kenmore 63252 Microwave Oven
HVM1750SMSS placed some aluminum foil and now the unit does not work. how do I reset it?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 16, 2011 | GE HVM1750SMSS Microwave Oven
I covered the plate with 'heavy duty aluminum foil' thinking it was safe for for microwave use, then I saw a sparkle inside while turning. I stopped it, took off the aluminum cover, turned the microwave...
The food is safe as long as the food has not got oxidized aluminium on it.
Microwave energy is very high and will melt metals!
As long as it is not arcing any more there should be no problem.
Jan 03, 2011 | LG Microwave Ovens
I put a metal pan with food inside my microwave oven. I heard a popping sound and there are now two tiny black marks pitted into the glass on the door. I can feel the two pitted marks from both inside...
Yes it is safe to continue using the Microwave as long as the integrity of the glass is not compromised and the pitted marks do not exceed 1/4 inch. The RFwave generated by the magnetron is a pretty wide RF wave beam.
If your really concerned you can take the unit to any appliance service center and ask that they perform an RF leakage test. There is really no other way to know if your leakage is within acceptable limits. I can tell you from personal experience that the ony microwave I ever saw demonstrated excessive leakage had either been dropped and had hinge or latch damage.
If your really worried about it and can not get to a service center you can do this test:
- Wrap a tall empty glass with a sheet of aluminum foil and place it about 3 inches away from the microwave in front of the area you where noticed the pitting.
- Run the microwave with a GLASS filled with water of equal size for 1 minute.
- Stand back 3 to 4 feet and watch for any signs of a spark on the aluminum foil.
- As soon as the microwave shuts off check the dry foil wrapped glass for any signs of heat.
(No heat.... no problem. Sparks or Heat = repair time.)
Thanks for choosing FixYa.
Kelly
Sep 21, 2010 | Sharp R-1480 Microwave Oven
Baked potatoes went up in flames now microwave has no power no lights. power outlet has 110v ac
Were the potatoes wrapped in foil? If so, the megatron tube was burned out. Replace unit.
Nov 06, 2009 | Kenmore 62622 Microwave Oven
Will tin foil in the microwave ruin it completely? The microwave turned off after my son mircowaved a potato wrapped in tin foil.
You should always put a spoon in a cup of liquid that you heat in a microwave oven.
The microwave with a potato wrapped in tin foil is like operating the oven with nothing in it! If the microwave was spotlessly clean then your in trouble.
1 put a cup of cold water in the microwave and set for 5 minutes. if the water boils then your lucky if it cold then go and buy a new microwave and stop your childs allowance for a fortnight.
One might ask the question how old is your child and should they be using such a machine unsupervised!
Nov 05, 2009 | Microwave Ovens
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
Microwave Ovens Logo
113 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
