Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Running to much and freezer to cold. Thermostat was just changed
I had sears come out and replace my thermostat on my frigidaire and it fixed the problem. Now the thing runs all the time and the freezer is way to cold on the lowest setting. Is it the wrong thermostat or a bad one? What could my problem be?
  • 10,865 Answers
This is under warranty. Just call Sears back and they will come out and fix it for free.
Posted on Apr 20, 2009
Refrigerator will not get cold
please check the defrost element and the defrost timer.
May 02, 2014 | Frigidaire FRS6R5ESB
FREEZER THERMOSTAT
Sounds like the thermostat is not working. Mechanical and electronic thermostats can go bad and cause the freezer to continue running no matter what setting is set on thermostat. When this happens the only setting that will work is turning the temperature setting to off. What is the model number on your freezer? Sea Breeze
Apr 03, 2013 | Frigidaire Freezers
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
It quit running and everything thawed. It's got electric going to the dial. plugged it in and can't hear anything running.
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Nov 06, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
How do I fix my frigidaire fridge the problem is the freezer ices up and no cold air blows into the fridge
Change out the defrost timer and defrost bimetal in the freezer. If yours is controlled by a control board then change the board and the bimetal thermostat in the freezer
Sep 05, 2009 | Refrigerators
Refrigerator does not get cold, motor is running, repairman says get a new one. only 1yr old (frigidair side by side)repairman said sealed system needs to be replaced.
Well, that's great for you since the sealed system is cover with a five year parts and labor warranty. Call a local Frigidaire certified repairman and tell him the situation.
Aug 05, 2009 | Frigidaire FRS26H5AS Side by Side...
I bought a used Kenmore upright freezer, it's been running all the time.
The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
Jun 02, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire Gallery FRS26ZGEB - 12 years old
you have a defrost problem or damper problem or evapator fan
1) Check the fan in the freezer is running
2) defrost the freezer (leave unpluged with door open for 24 to 48 hrs or untill it stops leaking water...
3) check the damper make sure it is opening and cold air is blowing
How you need to repair what defrost part failed
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Jul 03, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
186 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
