Question about Avermedia QUICKPLAY (pquickplay)
My vge socket only hase 14 prongs is this right
    President:
  • 948 Answers
If you're referring to your vga (not vge) no, it should have 15.
Posted on Apr 20, 2009
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Dell lattitude cpx charging pin and - TERMINALS
What? Is it time to wake up?
Oh yeah, Dell Latitude CPX,
http://www.amazon.com/Dell-Latitude-Notebook-650-MHz-Pentium/dp/B00005UJYF
AC adapter example for above,
http://www.prontocharger.com/ProductDetails.asp?ProductCode=d1161
DC Power Jack example,
http://www.all-power-jack.com/Dell/Dell-Latitude-CPx.html
I see the dilemma. The plug from the AC adapter has 3 socket holes, and the DC Power Jack has 3 prongs.
DC electricity has a Positive connection, and a Negative connection.
To find out which socket holes are for Positive, and Negative, let's look again at the DC Power Jack,
The Top view shows the jack upside down, and turned around. (In relation to how it mounts on the motherboard )
The bottom left view shows the jack primarily how it sits, (Mounted), on the motherboard.
The bottom right view shows the jack turned over, laying on it's front.
Also laying over to it's right side.
Note the three prongs. (Flat bladed pins )
The one in the middle is Positive.
The two outer prongs are Negative.
Looking at the bottom Left view, the Top prong is Positive, and the two bottom prongs are Negative.
Match it up to the plug on the AC adapter cable.
Going to test the Voltage coming out? (20 Volts)
The red Positive probe lead goes into the top socket hole, in the plug.
The black Negative lead goes in either bottom socket hole.
What if I'm wrong?
A Digital multimeter will just show a negative value. -20
An Analog multimeter's needle will go down towards the 0, instead of towards 20 Volts. (DC)
Just switch the probe leads around.
For additional questions, or if I am way off base, post back in a Comment.
Regards,
joecoolvette
Apr 29, 2012 | Dell Computers & Internet
My mitsubishi verada 97 requires H7 light bulbs although some one has fitted H4 bulbs which are three pronged. H7 are 2 pronged but narrower and will not fit socket. Is there an adapter or a workaround....
Veradas use a special two pronged bulb. I'm not sure if it is a two pronged h4 or a larger h7.
Switch you're high beam lights to the normal beams for the time being (assumeing they are working fine) then take it to mitsubishi for new bulbs
Sep 17, 2011 | Mitsubishi Lancer Sportback Cars & Trucks
I cant use my webcam in my netbook
If it's built in, you may need to install, or re-install drivers for the webcam.
Mar 29, 2011 | iTEKIRO Replacement Netbook AC Power...
Low beam light bulb issue rsx type s acura 05-06
The three prong base is just the bulb holder.
Here is an excellent tutorial on how to change the build:
http://forums.clubrsx.com/showthread.php?t=303640&highlight=change+bulb
Jan 22, 2010 | 2005 Acura RSX
Driver ok but no audio. hasee t2050
First, doublecheck that the headphones or speakers are connected to the correct socket and are working. Obvious I know, but it's surprising how often that catches people out.
Next right click onthe speaker icon in the tool bar (bottom right corner) and open volume mixer and ensure volumes are well up.
Finally go to Control Panel | Device Manager | Sound Video and Game controllers and ensure everything's working as expected.
That should sort you.
Simonides
Oct 10, 2009 | Microsoft Windows Vista Ultimate Edition
Outlet has 3 holes and dryer cord has 4 prongs,what do i do to use existing cord
A 4-prong dryer cord means your dryer requires 240 volts, and will not work with a normal 120V household outlet.
Is your existing outlet a normal outlet like every other one in your house, or is it three holes in an unusual pattern?
If you want to get technical, I'm guessing that your dryer cord is a NEMA-14 (see the picture to the right for examples of NEMA-14-30 and 14-50 plug patterns)
I'm also guessing that the outlet is a NEMA-5 outlet.
If either of my guesses are wrong, let me know what picture/description best fits your cord/outlet and I'll try to help as best I can.
Aug 02, 2009 | Whirlpool Dryers
I formated ma computer and my vge seems not to adjust it self,i i use a compaq flat black desktop,..
Right click on blank part of screen. Click properties. Click settings. Move screen resolution slider to the setting you want. Set colour quality. That should fix your problem.....
Jun 06, 2009 | Compaq Evo D500 PC Desktop
I have a 3-prong plug on a 14-year-old dryer. Now must change to 4-plug. Is that possible ... and if so, how?
A three Prong contains L1 (Line1), L2 (Line2) and N (Neutral). A four prong will contain L1 (Line1), L2 (Line2), N (Neutral) and G (Ground) typically a green wire.
Connect the three wires as normal, connect the green wire to the screw provided on the cabinet.
Jul 04, 2008 | Dryers
Avermedia QUICKPLAY (pquickplay) Logo
75 people viewed this question
Top Avermedia Televison & Video Experts
Vernon Taylor
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
