Question about Dell Inspiron 8600 Notebook
Kernel error 5 year old dell inspiron, push the power button to turn it on and after about 15 seconds of the windows splash screen, it will BSOD with a kernel error. I tried turning it on in safe mode and last known good config, but both ended with the same BSOD. Any suggestions would be appreciated.
  • tlely Apr 20, 2009
    It is a Dell Inspiron 6000 and 5 years old,  stop c0000135 unable to locate component This application has failed to start because kernel32.dll was not found.  re-installing the application may fix this problem.
  • Timothy Farley May 11, 2010
    Hi there.
    Can you tell me exactly what the BOSD says? Inlude any error codes it gives you.
  • 123 Answers
Use the XP CD to boot from.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the admin password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Also while in recovery console type in sfc /scannow to check all files.
Type exit to reboot the computer.
See if that works
Posted on Apr 20, 2009
Acer desktop power button faillure and STOP: c00021a BSOD problem
Can you do a system restore/recovery? Try boot to "last known good configuration" ? Have you added any new hardware or software?
Jan 07, 2013 | Computers & Internet
My Dell Inspiron 1545 PC notebook will not load to the WIndows screen. Once booted it just sits on a black screen with a moveable cursor. What can I do to stop this? thanks
Hi pebrouss,
Have you tried power drain? The easiest way to resolve this type of issue is by performing a power drain. Here's how you will do it.
1. First, turn off the unit completely. You may try pressing the power button for about 15-20 seconds.
2. Remove the unit from the power outlet.
3. Take out the battery from the system.
4. Press the power button for about 15-20 seconds.
5. Put back the battery and plug the unit to the power outlet.
6. Turn on the system and observe it.
Hope it helps.
Thank you for using FixYa.
Feb 22, 2011 | Dell Inspiron 1545 Notebook
Hello I have got suddenly a white screen after starting the 5 year old Dell inspiron 1300. In the background the typicall sound of the Windows XP startprocedure can be heard, but I dont get any readable...
Hi holm_fischer,
White screen often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
1. Turn off the computer.
2. Unplug the AC adapter from the power outlet and take out the battery from the system.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Turn on the system and try observing it.
--> If power drain did not work, you need to consult a repairman to have your screen be checked for possible damage.
Hope it helps.
Nov 28, 2010 | Dell Inspiron 1300 Notebook
Error loading operating system in dell
You may be right , the harddrive on the system may have gone bad.
You can run a diagnostics on the hardrive,shut down the computer, and then Press the Fn+ power button at the same time , it would initate the diagnostics.
Do post the results back
Thanks
proton
Apr 05, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
My Dell Inspiron 1000 Laptop would not power up.
possible power supply are motherboard possible bad pin on board
Mar 28, 2009 | Dell Inspiron 1000 Notebook
Touch screen issues
Has the unit ever been really wet or is there a hole in the touch screen foil? If not have you ever done a cold reset?
. First turn the unit OFF, then HOLD your thumb on the furthest bottom right hand corner of the screen, push as far into the corner as you can on the screen itself. While holding your thumb/finger on the screen press and hold the POWER ON button until you see the ZUMO splash screen, once the splash screen is up you can release the power, but continue to hold your thumb in the right corner of the screen for another 5 - 10 seconds, you should see a window that pops up and asks "Do you really want to erase all user data?", make sure to answer YES to this window, if you don't see this window, then turn unit OFF and try the above instructions again, ensuring your thumb is in the furthest portion of the bottom right hand corner of the touch screen.
Jul 23, 2008 | Garmin zumo 550 GPS Receiver
Dell Inspiron 8600 Notebook Logo
157 people viewed this question
Alun Cox
