Question about Dell Inspiron 1525 Laptop
Cooling fan Rattle
Inspiron 1525 duo core2 processor, cooling fan has begun to rattle, Bought new 6 mos ago, I don't want the same problem in the future, is there a higher quality replacement fan available and do I get at the fan by removing the palm rest?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Isn't it still under warranty? You'll devoid the warranty if you open.
    Sergeant:
  • 191 Answers
It should still be under warranty at 6 months old.
If you attempt to repair yourself, you will void the warranty.
Talk to Dell before you do anything.
Posted on Apr 20, 2009
Why my computer is too warm and shuts down repeatedly?
The issue seems with the cooling unit of processor.The unit is either dusty or faulty so you will have to replace/ clena it.
Thanks
Jun 15, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Dell Inspiron 1525 keeps overheating and switching off.
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Nov 21, 2009 | Intel Cpu Core 2 Duo T8100 2.10Ghz...
Problem with overheating.
Hi Dear. Always Pick n Place notebooks very carefully. When need to pick with both hands you can pick it in any direction but when need to pick with single hand, always use vertical position, without pressing and forcing any area. Place it on any flat surface where you are sure that exhaust system of CPU's fan is well ventilated. Heating problem may occure due to many reasons. Verify CPU fan function in BIOS, Clean CPU cooling fan and exhaust system with Electric Blower. NEVER use continuous charging, plug out charger wire when battry is 100% full, charg again when low battry alerts. This will increase battry life & backup time.
Apr 15, 2009 | Dell Inspiron 1525 Laptop
Need instructions on how to replace fan for dell inspiron 1525
The service manual has complete disassembly instructions, this is not easy.
Inspiron 1525 service manual
Mar 25, 2009 | Dell Inspiron 1525 Laptop
Have a 4wire motherboard for fan/heatsink on dell 530 inspiron
No need to buy a new fan, there are addapers to fix your problem.
Go to a good pc-store or order one from the net, the addapers are cheap to buy.
Good luck
Nic
Mar 13, 2009 | Intel Socket 775 Heat Sink and Fan up to...
Wifi take forever
There is a problem using WEP try switching to WPA-PSK this should solve the problem
If you cannot do this post and I can help
Jan 13, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Hi i m havung dell 1525 with core2 duo processor in it ..and at top of the dekstop there are 8 options like internet,web cam,help and support............is removed ..i can't see them now.........plz help...
sounds like the dell 'quickset' software has been removed- insert the driver disk that came with the 1525 and follow the install instructions - then scroll down until you come to the desktop software section and reinstall the control software - hope this helps
cheers
Nov 19, 2008 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
P4 ugrade required
Sadly you wont find any 1066Mhz FSB processors for the Socket 478. The best you can find is the 3.4Ghz with 800Mhz FSB. It might be cheaper and also better value for you to get a Socket 775 based motherboard and Core2 Duo processor. The value range E2160/2180 processors or the E4300/4400 processors have been tested to be even faster than the Socket 775 Pentium Dual 3.4Ghz and they also use less power.
An article on socket 478 for you http://www.xbitlabs.com/news/cpu/display/20040123103754.html
Dec 02, 2007 | Intel P4 Socket-478 Original CPU Cooling...
Dell Inspiron 1525 Laptop Logo
499 people viewed this question
Alun Cox
