Question about Biostar : K8VGA-M Athlon64/DDR400/A&V&L/MATX Motherboard (MOTBI07)
Cant install os
I have a biostar k8vga-m with an athlon 3400 512mb ddr 400 memory and a 500 watt antec psu i cant install any version of windows or linux it will says loading then stop responding yet i can load memtest and have no issues along with a cpu burn in test also i can use the bios with no porblems the cpu temp is 50c so thats not the issue ive tried a different dvdrom and still no luck any ideas?
  • shaunl Sep 21, 2007
    ive switched out memory tried a different cdrom and even tried botting it without a hdd to see if i could get the "hdd not detected" msg still no luck
    Sergeant:
    Champion:
  • 293 Answers
50c is too high. Anyway, either you have a problem with your memory, cd drive, or hdd.
Posted on Sep 21, 2007
SOURCE:
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    I bought a HP 6710f Pavillion desktop, running windows 7, and found out it only has a 250 watt power supply. I turned around and bought an Antec Greenwatts 500 watt ATX 12v v2.3 psu to install for future...
    Presuming you mean the Earthwatts 500:
    Should work, though the Earthwatts has the 24 pin ATX instead of the 20-pin.
    http://www.atxpowersupplies.com/manuals/Antec-Earthwatts-EA-500D-user-manual.pdf
    You just need to snap the 24-pin connector apart to make it work as a 20-pin. It can be snapped back together for future motherboards.
    The Bestec is just a standard ATX power supply
    Mar 23, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
    Turn on the computer nothing happen then smell burning from the power supply! turned off right away.
    That power supply is probably dead. try your motherboard witha known-to-be-good power supply to determine if your system has survived. IN my experience the failrate for antec sp450 watt psu is close to 40% over 4 years (300 pc:s at university), so there is a high probability that your psu is unrecoverable.
    Feb 13, 2011 | Antec SP-400 400-Watt Power Supply
    Pc keeps rebooting
    Try re-installing the operating system. It is possible it possible OS is not installed properly. ([email protected])
    Jul 19, 2009 | Computers & Internet
    Connection question
    It is for the Fan RPM Monitor according to Antec.Check your motherboard for a psu fan connection. Hope this helps & please take a moment to rate this solution. Thanks.
    Mar 11, 2009 | Antec Solution Series SL400PEC - Power...
    Memory Modules
    Short answer is no. You can not run PC3200 DDR 400MHz memory. The fastest memory the motherboard can run in the,
    (Biostar M7VIG 400) is PC2700 DDR 333MHz.
    If you do not have you're manual, you can download it by clicking on this link: ftp://ftp.biostar-usa.com/manuals/M7VIG%20400/M7VIG400manual.pdf
    Biostar M7VIG 400 main web site, click this link:
    http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
    Good Luck!
    Mike
    Jun 18, 2008 | Biostar Mainboard M7VIGD-A02 VER:6.0...
    Problem with DDR
    If the memory is good (test it on another comp. ) it may be possible that the motherboard does not support that type of memory (happens !! ), or it supports that quantity of memory only on one slot . U must get the motherboard;s manual and read there if they are any particularities..... (sometimes , very rarely, there are BIOS settings ...that may interfere ... )
    Jan 13, 2008 | Biostar K8VGA-M Motherboard
    How to turn off on board graphics card
    get into the bios of your computer. (look it up on the internet if you don't know how) search around, there should be a setting in there for onboard graphics. most likely in a "devices" or "advanced devices". this is just off memory but keep searching and don't play around with other settings. ^^
    Dec 28, 2007 | Biostar K8VGA-M Motherboard
    Upgrading power supply
    The next time you get a PSU. Tell them what you have. Apparently you got one that is not compatible with your compaq.The power (500 wattage) will work with your MB.
    Get an OEM PSU from Compaq(HP).
    Dec 02, 2007 | Compaq (253219-002) Motherboard
    Open Questions:
    See all Biostar : K8VGA-M Athlon64/DDR400/A&V&L/MATX Questions
    Biostar : K8VGA-M Athlon64/DDR400/A&V&L/MATX Motherboard (MOTBI07) Logo
    70 people viewed this question
    Top Biostar Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Alun Cox
    Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
