Question about Frigidaire ATF6000ES Front Load Washer
Washer wont drain
My frigidaire washer wont drain
  • 1 more comment
  • marcellarayk Apr 26, 2009
    The washer runs fine up until it is time to drain the water. Then it pauses and will not move pass that point.
  • autumnrunyan May 10, 2009
    Actually the problem was the bladder was clogged so i took it apart and cleaned it. then it ran fine
  • buick1985 May 11, 2009
    i need to know how to get front panel off a afinitty front loader or can i tilt it far enough to reach filter with throwing off thedrum balance
    Genius:
  • 1,198 Answers
I had a Splendide that would do that. To spin and pump out, it actually ran in reverse! I finally found a loose connection on an electronics board near the motor. Another time the big capacitor had a dent in it and wouldn't work anymore. That keeps the motor from starting.
Posted on Apr 27, 2009
Why my frigidaire top loader wont spin?
Hi - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Oct 18, 2012 | Frigidaire FEX831CS Top Load Stacked...
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire front load washer LTF2940FE0 wont drain
That loud noise is most likely debris bouncing around inside your water pump. Pull the 2 hoses off and try removing it by hand, or un-bolt it from the floor pan and tip it sideways to shake any small objects out. I found a mans wedding ring in there once.
Mar 18, 2010 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire washer will not drain. It work
check all the drain hoses for something caught in the line to the drain from the tub thru the pump to the stand pipe at the drain,you may have a plugged line and machine pump wont start due to this restriction
Mar 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
WONT DRAIN
clean the pump and also make sure that the pump motor is powered during draining
May 30, 2009 | Frigidaire GSTF1670A Front Load Washer
Washer wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 02, 2009 | Frigidaire FEX831CS Top Load Stacked...
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
286 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
