Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Water boiling hot at all times... how to change thermostat
How do you change the thermostat for a GE Smartwater hot water heater? The water is boiling hot at all times. We are women and we're clueless! We may lose our house and don't want to put more money into it if possible. Thankk!
  • musikmel Apr 21, 2009
    got it fixed! Thank you, Melanie
  • 10,865 Answers
Http://www.naturalhandyman.com/iip/infwaterheater/infwhadjust.html
click on this link and you will see exactly how to proceed. Get back if this info doesnt provide you with the level of assistance u need as I can also talk u through it on the phone, or make a house call.
Posted on Apr 20, 2009
Not enough hot water ge smartwater water heater electric
1) Test elements:
http://waterheatertimer.org/How-to-test-water-heater-element.html
2) If elements test out ok, then replace both thermostats. There is no reliable way to test thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) No leaks is good news. Inspect for leaks is important step for longevity of water heater.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Mar 12, 2013 | Water Heaters
Not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
GE Smart Water Hot water heater 40 gal will not stop heating water.
1) For gas: Turn off gas to heater:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
2) For electric: Turn off circuit breaker.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#veryhot
3) For gas: Copy following link to identify gas control valve thermostat, and troubleshoot by type of gas control.
4) For gas: Gas control valve thermostat has probably gone bad.
5) Add comment and give clear description of water heater.
6) Call plumber.
Feb 17, 2013 | General Electric GE SmartWater Household...
Limited hot water from 62 gal ge model D03666 looking for type and how to replace heating elements
Open following links to get started.
If water heater has NO hot water, then best suspect is ECO reset button tripped on upper thermostat. Open upper cover and push in red reset button. If reset keeps tripping, I usually replace both upper and lower thermostat.
If water heater has some hot water, then upper element is good so test lower element.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | General Electric GE SmartWater Household...
I have no hot water in my home i can not locate the reset button
The reset button is located on the top thermostat, on the heater you will see a acess panel with screws in it to remove the thermostat and element is behind this panel. Once removed the top thermostat should have a red button to press to reset heater.
If it resets then wait for a little time for hot water. If this doesn't work then it could be the elements are in need of changing.
Apr 09, 2011 | General Electric GE SmartWater Household...
Hot water does not last long. Hot water heater is a 50 gal ge smart water heater. It takes a long time to heat and is not very hot when it reaches shower in the back part of house. Where are the coils or...
probably has a bad heating element. May be a little limed up also. Drain the heater and replace the elements. Take a special tool to remove and replace the elements. ( fairly cheap) You can probably get the elements and parts at a good hardware store. The people at the store probably will explain to you how to replace them. Feedback please if this was of help
Feb 20, 2010 | General Electric GE SmartWater Household...
Voltage varified correct to top thermostat
change the thermostat on both upper and lower elements, and the elements depending on the age of the water heater, if it is over 6 years old consider changing the water heater,
May 06, 2009 | General Electric GE SmartWater Household...
Elec water heater no hot water
Check the breaker to see if the unit is getting power. You will need a voltage meter to check out the thermostat on the unit and also you will need to use it to check if the elements aren't blown. Sounds like the unit isn't getting power but could be the thermostat located under one of the panels on the side of the unit.
Mar 20, 2009 | General Electric GE SmartWater Household...
Hot Water inconsistent
Something you can do, following your fathers logic,   is to attach a hose to the drain of the tank and run water from the bottom of the tank into a drain untill all the sediment is removed (Water runs clean). This is normally done once a year as preventive maintenance  on all tank type water heaters. The logic sounds good to me.
Feb 16, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
240 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
