Question about Gateway MX841 PGA370 NLX Motherboard (4000773)
Ide not detected
When i start the computer BIOS do not recognized any of ide drives. i check the power and it is OK.
  • petar ilic
    petar ilic Sep 21, 2007
    to be more specific, no hdd and atapi cd rom are detected, at the same time. this problem is started wit no (for me)visible reason.
    Sergeant:
    Champion:
  • 293 Answers
BIOS Try setting the BIOS settings to Auto detect any IDE Devices. POWER Try using a spare Molex Power Connector IDE CABLE Try using a space IDE\SATA Cable. Make sure all are properly locked down into the sockets. (Mobo and HDD) SOUNDS and VIBRATION Since all HDD's are mechanical devices they produce sounds and vibration. Make sure they have this else its a powre problem or your HDD is defective. ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 21, 2007
SOURCE:
My dard disc wont detict
When installing a new hard drive, a PC may not recognize the hard drive. Incorrect cable installations, jumper settings and BIOS settings may cause the computer to be unable to detect your hard drive. Due to the vast differences in hard drive types (IDE versus SATA) and brands, motherboard brands and types, and BIOS types and configurations, please download or acquire your motherboard and hard drive manufacturers' documentation prior to acquiring a hard drive. Make sure that the type of hard drive you plan to purchase is compatible with the motherboard.
Shut down the computer. Unplug all cables and peripheral devices. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs. Please see your case manual if you are unsure.) Locate the newly installed hard drive. Check that two cables are running from the hard drive to the motherboard and to the power supply. If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s). Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections. Restart the computer. Enter your BIOS immediately. (Your BIOS usually alerts you to the key required to adjust settings. If your screen does not show this information or if you are unsure, consult your motherboard manual.) If it is an IDE hard drive, enter the IDE settings. The BIOS should show the hard drive. Configure it as primary or secondary, according to your computer's configuration. (If you have only one drive, set this to primary. Otherwise, set as secondary.) Save your settings, and exit the BIOS. Once you are certain that the the PC is recognizing the hard drive, replace the side panel. Detect a SATA Hard Disk If you have connected a SATA (serial ATA) hard drive to your computer but are not able to access the files on it, then your system may not be detecting the drive correctly. On either a PC or Mac computer, you can manually detect and mount a hard drive that is locally connected. Once properly detected, the drive will become available for file transfer.
Plug the SATA hard drive firmly into your PC computer and ensure that the drive is powered on. Open the Start menu and click on the "Control Panel" icon. Open the "Administrative Tools" folder and double-click on the "Computer Management" icon. Go to the "Disk Management" tool on the left side of the control panel window. This brings up a list of all drives currently connected to your computer. Right-click on the SATA drive that you want your computer to detect and choose "Change Drive Letter and Paths." Click on the "Add" button and then select the drive letter that you want to be assigned to the SATA hard drive. Click "OK" to save the settings and detect the SATA drive. b> Mac Instructions b> Plug the SATA hard drive firmly into your Mac computer and ensure that the drive is powered on. Open a new Finder window and navigate to the "Utilities" folder, which is located in the "Applications" section of the Mac hard drive. Double-click on the "Disk Utility" icon. Highlight the SATA hard drive that you want your computer to detect from the list of connected drives on the left side of the window. Click on the "Mount" button at the top of the window to have the system manually detect the SATA drive. Hope this helps.
Dec 29, 2012 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Computer shuts off randomly
i suspect that there could be driver issues on your system that made your computer to shutdown, if you stil changed your power supply, and cd drive, then there might be a problem with the cable that you are using or the slot from your motherboard. If you install the cd drive you should check first from bios if it can be detected. Is your drive an IDE or SATA?
Jan 10, 2010 | Dell XPS 410 PC Desktop
My computer worked properly. but at once my IDE devices started giving troubles. my 2 IDE devices are not detected at the start up.
The BIOS will have trouble detecting faulty IDE devices, eg the hard disk etc.
To check if the IDE devices are faulty, connect the hard disk to an USB hard disk adapter and plug it into a working computer's USB port, if the computer detects it as an external hard drive and you can open the folders and files then the hard drive is OK and the fault is the disk controller. If the hard disk is not detected then it is faulty and a new hard disk is needed, Windows installed on the new hard drive together with the device drivers and your programs to get an fully functioning computer again.
Sep 01, 2009 | Intel D865GBF Motherboard
Hard drive goes on blue light go around once pc
Tried to boot the computer in bios. Check if the harddrive is detected in bios. If not detected. Shut down the system,take out the power cable.open the tower and disconnected the hdd IDE cable and connect it to a differnet IDE port. Restart the system and boot in bios check if hdd detected. If still not detected possible issue with hdd. Try connecting on different computer if still issue persist replace Harddrive.
Aug 18, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
2nd Hard drive not recognized
If your using IDE hard drives i would try to put them both on the same cable on the primary IDE controller. Then set you main hard drives jumpers and the second hard drive to cable select not slave. Try to boot if the boot fails your goiong to need a Windows 98 boot floppy with FDISK. You need to start up the 98 boot disk with out CD support then when it reaches a command prompt start fdisk. ONce fdisk is up format and partition the second drive. Now it should work. :) Check that the harddrive is detected in the BIOS, it may have become disconnected, it should also be the master drive on the primary IDE. If the drive is not detected in BIOS there is little chance of it working
Thank you....
Jan 29, 2009 | IBM ThinkPad X31 2672 Notebook
New ECS G31T-M won't recognize IDE devices
Locate the boot options in your BIOS and set it to boot from the Hard Drive
Oct 13, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
Computers & Internet Logo
327 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
