Question about Kodak Carousel 5600 Slide Projector
Light won't come on, replaced old light bulb.
I have a Kodak carousel 5600 projector that use to work but now doesn't. I understand that a new light bulb was put in the projector but no light comes out of it. Anideas? Len
    President:
  • Kodak Master
  • 412 Answers
First, check to see if the lamp lights at all (spill light coming out of the projector near the fan). If it does, then the problem could be just the "dark shutter" not opening. If the lamp does not light, it could be a couple of things: it could be the lamp thermal fuse has opened or it could be a bad lamp socket.
Sounds like you need to seek out a factory-trained repair dealer for this one, to narrow down the possibilities!
Posted on Jan 04, 2011
Why won't the bulb work on the kodak carousel 750H
Those bulbs do burn out eventually, and need to be replaced.
Oct 26, 2015 | Kodak CAROUSEL 750HAR ELH Light Bulb Lamp...
My slide projector light won't come on. Every thing else works
Check the base where the bulb connects, pins get bent and don't connect to bulb at times
Nov 18, 2014 | Kodak CAROUSEL 650H ELH Light Bulb Lamp...
Where can I purchase a bulb for my Kodak Carousel 4400 Projector
FHS Bulbs can be found online (Amazon, Ebay, Bulbman etc) or if you have a "Batteries + Bulbs" outlet in your community, you can find it there. Good Luck !! Jim
May 13, 2014 | Kodak Carousel 5600 Slide Projector
My kodak carousel 5600 slide projector wont stop advancing unless i unplug it
You are experiencing a fairly common problem called continuous cycling. It is caused by use or mis-adjustment.
If you feel comfortable with a electro-mechanical adjustment, take a look at the attached picture for the correct alignment of the cycle contacts. The positioning is critical for correct operation.
Turn the projector upside down (unplugged), and remove the bottom screws. Then carefully remove the bottom cover. The cycle contact assembly will be in the center of the projector.
If you need help, contact a authorized repair dealer. Good Luck!!
Jun 21, 2011 | Kodak Carousel 5600 Slide Projector
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
I am trying to locate an instruction manual for a Kodak 5600 carousel slide projector. Will pay a reasonable price!
Kodak has an e-copy of the manual on their website:
http://support.en.kodak.com/app/answers/detail/a_id/19709
I hope this helps !!
May 13, 2011 | Kodak Carousel 5600 Slide Projector
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Kodak Carousel 5600 Slide Projector Logo
252 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
