Question about Dell Dimension 4700 PC Desktop
I Can turn it on, but nothing come out the screen output
I have a 4700, was going to shove in some more RAM and another Hard drive, but in the process all boots ended up in just beeps, so i put it back how it was, and now it boots up fine, or at least it sounds like it does, but nothing comes up at all on the screen, not even the bios screen :/
  • 1 more comment
  • alzrnbinbath Apr 20, 2009
    Thanks, I eventually managed to get it actually how it was, and it booted, then managed to get the other ram in there and booting too, :)
    Thanks, though it turned out to be the ram, the computer has integrated graphics, and i had done a fair amount with the plug in, and never disconnected the video cable, which was my main worry, but apart from one of my old ram chips being dead everything has sorted itself out nicely
  • Frank
    Frank May 11, 2010
    make sure every thing is back to original. reseat the memories. and make sure the memories is snapped in, no wire hanging that should be on the mother board.
    Problem Solver:
  • 18 Answers
Please make sure that the monitor cable did not shift while moving the system. If it is even slightly off it may not show up. Also when you were in the computer did you happen to notice if the video is from an on board graphics port or a video card that sits in either a PCI, AGP, or PCIe slot? If it sits in a slot make sure that it is firmly in.
For future reference you need to make sure that the RAM is designed to be used in your system or it will give you that beep code and not start up.
Posted on Apr 20, 2009
    Novelist:
  • 90 Answers
A couple of things could be happening. You didn't get the video card reseated correctly in the slot when you removed it from the machine. Hopefully you had the power cable disconnected from the computer when you did all this. You plugged the video into the wrong video port on the computer. You bent a pin on the video cable when you reinstalled it. You forgot to plug the monitor back in or turn it on. Once you are up and running install the HDD first and the restart the computer. This should boot up correctly and you can get the formatting all done. The memory is a different story. The memory has to be matched in type and speed in order for it to work. it also matters which slots are populated with the memory. Read the owners manual on making any upgrades to the system. If you don't have one you can download it from Dell on line and print it out. Good Luck, RAC
Bought a dimension 4700 at the local goodwill and am having trouble getting it working
It sounds to me like the on-board HDD controllers are dead. Have a look at the motherboard... I'll wager you'll see a fried capacitor right in the middle. Common Dell failure :(
Jul 20, 2014 | Dell Dimension 4700 PC Desktop
My desktop 4700 when turned on there is a buzzing soud about 6 times off/on-also the mouse,monitor,keyboard inop.monitor shows power saver on & goes off
I am going off of the assumption that the buzzing sound you refer to is actually the BIOS Post Code since your are not seeing the post check screen. With that in mind, you should reseat your motherboards memory sticks (not the hard drive, the RAM). Be sure to of course power off the computer, use a grounding strap and generally follow all safety steps for basic PC maintenance.
May 14, 2012 | Dell Dimension 4700 PC Desktop
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
Ok hello i just got a free dell dimension 4700 and i know its wayyy out of date i just like tinkering with it i have a hp laptop g62 and everything but anyway back to what i was wondering ok i turned it on...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
try uninstalling a few unnecessary programs
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task on restart
then defragment your hard drive
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer
also select users you will see who is using your computer
hope this helps
Jan 13, 2011 | Dell Dimension 4700 PC Desktop
The laptop has power but the initialization process doesn't complete. Dull gray screen is all I get.
Please follow the diagnosis outlined in this article to check whether the backlight lamp or the inverter board are the root cause of the problem or not:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
If you connect the external monitor & nothing is displayed on it, then this means that both the backlight lamp & the inverter board are fine. The main indicators in these cases are the sound, and the hard drive LED on the laptop case. If the laptop sounds just like it always does for a minute or two after being turned on, it means it's going ahead and booting the operating system, but the video processor or part of the motherboard circuit for video output has failed. If the laptop just sits there and beeps when you turn it on, or if you hear the fan but not the hard drive chuckling with its active LED flashing away, it means the laptop isn't getting as far as trying to boot the operating system. While this could be due to any number of hardware problems, the most common and easiest to
troubleshoot or repair is RAM failure. If your laptop has two RAM modules installed, try booting with just one and then the other in the primary slot. If your laptop only has one RAM module, you might consider buying one online from a site with a good memory selector, like Crucial.com
Oct 23, 2010 | Toshiba Computers & Internet
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
When I turn computer on the windows boot manager screen comes up. It says windows is having problems communicating with a device on the computer. It says this error could be caused by a removable storage...
Sometimes when you use ram sticks on some older computers they do not handle taking teh ram stick out of the USB port without first closing out teh device OR if you have the RAM stick in while you are booting the machine... it will select the ram stick as the boot device and appear there is no oprerating system present.
In you case when you go to the boot menu.. be sure the boot menu is set to select the hard drive as the primary boot device. If it is not then you can make the change at teh bott up screen.
Oct 04, 2009 | Dell Vostro 1510 Laptop
Beeps, wont boot up
Most of the time when it beeps, and there is nothing show on the computer screen, it is a RAM problem. A stick of ram may have gone bad. If you have two sticks of ram in the computer, you can try to remove one stick at a time to see which one might have gone bad.
Mar 23, 2009 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
128 people viewed this question
Alun Cox
