Question about Dishwashers
My GE Profile dishwasher is leaking under the tub. Its not a small leak, the water comes out as soon as it starts to fill. What may be the problem?
  • emccain Apr 21, 2009
    It is the water pump seal. I fixed it last night.
  • 10,865 Answers
You have one of two problems here. First of all remove the lower front panel on the dishwasher and get down there with a flash light and check it all over. The water leak is either where the water line is connected to the machine, or around the motor/pump seal. Close the door and turn on the machine. Now you will see exactly where the leak is. IF if is the motor/pump seal you may want to call a technician. If it is where the hot water feeds the dishwasher you may be able to tighten up the connection.
Posted on Apr 20, 2009
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
Water is coming from the bottom
Take off the panel at the bottem of dishwasher and find leak. If leaking from water supply connection try to tighten it first. If that does not work turn off water under sink and replace warter supply line. You can get a easy to handle braded line at you local hardware store. Replace other leaking parts at www.repairclinic.com.
Mar 24, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Kenmore Dishwasher leaking from bottom but not while draining....
Leak is associated with the water pump, either a hose or seal
Sep 29, 2009 | GE 24 in. GSD4020Z Built-in Dishwasher
LEAKING FROM BOTTOM
Is it leaking only when it is filling or all the time? If it is only leaking during fill, it could be an air gap device
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • If it is leaking all the time it could be the main tub seal. Hope this helped.
    Jul 16, 2009 | Roper RAS6233KQ Top Load Washer
    Leak from dishwasher fill funnel
    Hi . the air gap is required by law, to have it there.to stop water in the tub, to end up in your water system, which would never happen. try setting the pressure down, and use the dishwasher. it should work fine . turn down taps ,till it stops leaking . should be ok
    Oct 06, 2008 | Kenmore 15129 Built-in Dishwasher
    My Ge washing machine is leaking from the Bottom
    It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
    During fill only
    During drain and spin only
    All the time
    During fill only
    If the washer leaks only during the fill cycle, check these:
    A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
    All the time
    If the washer leaks all the time, check these:
    Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
    Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
    Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
    Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
    Aug 12, 2008 | GE Profile Performance WPSF4170WAA
    GE Top-loader Leaks Water from Vert Tube Behind Tub on X-Large Loads
    During fill only
    All the time
    During fill only If the washer leaks only during the fill cycle, check these:
    During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
    All the time If the washer leaks all the time, check these:
    • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
    • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
    • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
    • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details
    If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jun 18, 2008 | GE WBB4500EWW Top Load Washer
    GE top load washer leaks on floor
    Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
    Dec 29, 2007 | Washing Machines
    Whirlpool dishwasher leaks everywhere
    your tub seal needs to be replaced. you might have damaged it when you moved it
    Jan 25, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
    Dishwashers Logo
    156 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
