Question about Sylvania Audio Players & Recorders
HOW LONG DOES IT TAKE TO CHARGE
IT DOES NOT TELL IN THE MANUAL. hAVE CHARGED SEVERAL TIMES BUT HAVE STOPPED BEFORE THE LIGHT WENT OUT. MANUAL SAYS WHEN FULLY CHARGED LIGHT WILL GO OUT.
    Sergeant:
  • 191 Answers
Is it new and you are trying to charge for the first time?
First time charges can take up to 12-24 hrs. depending on the device.
Posted on Apr 20, 2009
Charging/Charged Indicators
I don't know what model of radio, but here is what I would try: pull the batteries and charge them on the charger by themselves if your charger allows this. The lights, well, some manufacturers just miss the boat. Especially on low end or "beginner" radios. I have one brand I can insert with NO BATTERY and the light comes on. Talk about useless. Charge times vary by size of battery and charger output, minimum is 3 hours, 12 hours much more likely but I see a lot at 5-7 hours. Hope this helps, model and brand helps always.
Dec 12, 2015 | Walkie Talkies Radio Communications
Wont turn on keeps flashing a red light
The batteries may not be able to charge or charge completely.
Jan 29, 2015 | Aftershokz Sport Bone Conduction Headphone
Why stopped at light went to move and would not. i moved the shifter several times then it move but jerked.
Check the transmission fluid level first and make sure it's full. If it is full then a trip to a transmission shop would be the next step. It's quite possible that a simple fluid and filter change may fix the problem.
Aug 02, 2014 | 2003 Hyundai Santa Fe
Will not charge
Sounds like you have a bad battery. Check your users manual for how to change it.
May 01, 2017 | Nikon COOLPIX S9500 Digital Camera Black
I plugged in my battery to the charger, it showed red, charged for a couple of hours, showed green. i used the wg151 trimmer for about twenty minutes, batter went dead , trimmer stopped. i plugged the...
Sometimes, batteries tend to show charge but they are not completely charge. Reason is that they have got weakened and needs to be recharged properly.
For this, I would recommend you to use Nicad Battery Repair Manual. It would charge the crystals inside the battery completely and make them work like the new ones. Hope it would be useful for you. Take care.
May 31, 2011 | Garden
Battery warning light was on this morning , and for several miles altrnated between being on and off. After several miles it got dimmer and finally turned off. Car seemed to run all right though.
Replace the battery. The batter is on it's last leg and is about to die. The reason the light went off is because as you drive, the alternator provides charge to the battery. So the further you go, the more charged the battery becomes. That said, if the Battery warning light was on when you started the car, and you had not left any interior lights on over night, then the battery is losing charge rapidly or is not holding a charge.
May 16, 2011 | 1999 Honda Civic
Unit powered off. I unplugged for 10 secs, replugged in. Unit powered on numerous lights flashed in sequence and went out. Power light was last light on. It flashed several times then went out.
It's trying to tell you something. Look up the series of flashes in your manual and see what it's trying to tell you. If you don't have a manual, go to the manufacturer's web site and see if you can download one.
May 06, 2011 | Office Equipment & Supplies
The original battery stopped working. Whenever we picked up the phone it just made a very loud noise in our ears. Now I ordered replacements batteries from ebatts. The red light is always on, slightly...
place the phone in the BASE for several seconds then try it. make sure it is the base and not a stand alone charger. if this does not correct it ensure you have the correct replacement battery for the phone. be aware the first time you charge it ... it has to be charged for at least 12 hours
Dec 08, 2010 | Dual Maxus 5.8GHz Handset Cordless Phone
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Glow bouy will ony stay on for 45 minutes
According to the owners manual for these swimming pool lights, if you light is not working for the full amount of time expected (at least 4 hours) you should try the following troubleshooting steps:
1. The battery pack might not be fully charged. Check the charge and recharge if necessary.
2. The battery pack or charge might be defective. Run the light through several charging cycles. If it fails to hold a charge but the indicator lights are showing normal operation, take the light to an authorized repair shop.
3. The battery pack might be old. After approx. 600 charges, the batteries might lose their ability to be charged. If this is the case, take the light to an autorized repair shop to receive new battery installation.
4. The product might be overheated. The light's internal temperature regluator will shut of the product to prevent damage. Allow the light to cool down and then test for normal opperation.
Jun 15, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
249 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
