Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Frozen cable 4 stering on motor side boat is a year old cable apears to be rusted solid mercury says cables should be lubracated but there is no way to do this .the manual does not state this prrcedure
    Sergeant:
  • 187 Answers
There is a cable lubricator that looks like a syringe with a hose and clamp on it to attach to the cable. I have never used one but it looks like it would work well. As for the cable it is better to replace it than have it brake at the worse time.
Posted on May 13, 2009
Proper Maintance program for 1986 mariner 150 hp 2 stroke boat motor
The biggie is changing the lower unit oil,, making sure its not getting water inside,, R&R the fuel filter, R&R spark plugs, grease all fittings.. DOUBLE check the steering cables... they rust and corrode from the inside...NOT fun to be in a boat when the steering cable breaks!!!!!
Mariner Outboard Service Repair Manuals by Seloc 1977 2004
Jul 08, 2017 | HP Boating
I have a 2000 mercury 125 hp that is very tight to turn i thank its by the motor
Hey Bryan,
When was the last time you greased the steering pivots on the motor?
If this boat has manual steering, your cable(s) are getting a little rusty... may be time to replace them.. they ARE your life line.. (I was in a bassboat that the steering cable broke.. INSTANT 120 DEGREE Right turn..!!)
Jun 12, 2017 | Boating
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
Steering gear
Hi Alfred.
Your answer will depend on the fishing boat.
For really small boats, with an outboard motor on the back, the motor will be on a pivot joint, and have a handle in front. You point the running motor side to side to steer the boat.
Larger boats with outboards will have a steering wheel with a mechanical linkage to an outboard motor or motors that will pivot them side to side to steer.
Larger fishing boats, especially commercial boats, will have an inboard engine and prop shaft, a fixed external propellor or propellors, and a rudder that is connected with a mechanical linkage to the steering wheel or ships-wheel to move the rudder side to side and steer the boat by deflecting how the water flows by when under way.
Hoping this helps.
D
Gidday,i am trying to find out the year of my 50 h power mercury blue band . The serial number I have is 8016593 and I am looking for both the inner and outer wiring harnesses
50 hp is a 4 cylinder powerhead.. blue band denotes 80s model engines.. my dads was a red band 69 model.. the red band stopped in the late 70s like 79 .. the wire harnesses are almost identical from 40 hp on up to about 80 or higher, just a heavier set of starting cables.. may need to check into used equipment.. might find something easier there.. check mwith a mercury dealer near you also..
Nov 19, 2014 | Light Outboard Motor Boat Bass Fishing...
Mercury outboard problems
the primer going flat indicates that the fuel is getting a vacuum in the system
the most obvious place is the vent in the fuel tank cap not being unscrewed to allow air in as the fuel is being used or that vent hole is blocked or rusted up
if by chance you have being using E fuel, it is now known that ethanol attracts water and separates from the fuel
that water attraction rusts tanks , corrodes alloy parts and destroys rubber hoses
it is especially not recommended for use on marine vessels and outboard motors
so the problem could be a stack of rust in the tank blocking off the inlet line
Mar 26, 2017 | Boating
Stearing on my 4yo 60hp mercury outboard will not budge
if you have "rotary" or "rack and pinion" steering. what your dealing with is rust. 2 things you can do to test the steering system. (1) tilt engine all the way down using the trim an tilt system. On the engine, you will see a steering rod that is parallel to the transom. One side of the rod is connected to the engine(ignore that connection), the other side curves down and connects to the steering cable. Disconnect steering rod from cable by unscrewing the nut counter clockwise. Once you disconnect the steering rod from cable. Push steering rod forward towards bow swinging it out of the way. Engine is now free from boat steering system. “Testing the engine steering tube“ all you have to do is manually turn the engine port and starboard using your hands. If your able to turn engine, the problem is the boat steering system. which you can fix. If you can' turn the engine then the job will require the engine to be removed from boat and transom bracket rebuilt. Take it to a repair shop.(2) with the engine still disconnected from the boat steering system. Get in the boat and turn the steering wheel. A good steering system you should be able to turn the wheel with just a finger. If wheel does not turn, you have one of two problems. Bad cable or bad steering helm. I always tell my customer to change both as a kit as a safety issue. if you are trying to save money. pull cable from helm, turn wheel if it turns easy replace cable (keep cable don't throw it away you have to get it matched) if wheel still stuck replace helm.
Oct 31, 2009 | Boating
Mercury 115 problems
This could me that reverse gear is not fully engaged.Adjustment on the cables is needed.Take the cowlings off.With the motor not running,move the throttle/gear selector into forward and reverse.You will see where the cables move in the engine area.Note which way the cable moves the selector when reverse is selected.Do this next bit from inside the boat.Hook up the flusher to the motor and start it.Select reverse.When you hear the grinding,push the selector by hand in the direction of travel.It should engage the gear fully.You will see the adjustment threads on the control cables.Move to suit.Hope this helps
Jul 28, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
100 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
