Question about Acer Aspire One PC Notebook
My acer aspire 5315 doesnt boot up the power
My acer aspire 5315 doesn't boot up the power light and battery charing light doesn't go on even when plugged into the adapter how do i know if its battery or adapter problem?
    President:
  • 987 Answers
Remove the battery and plug in power..if it works then your battery having problem..if not then ur power adpter having problem...
Posted on Apr 20, 2009
Acer 5315 wont turn on and wont chare, no lights at all on laptop but charger fully working.if i eventually get it to turn on it turns straight back off
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Nov 04, 2011 | Acer Aspire 5610-4648 Notebook
The Acer 5315 notebook I have will not power up. It is plugged in and when I press the start button, the power light is on for about 2 seconds and then it shuts down. I removed the battery and it will not...
most probably it is the motherboard. try to turn on the computer using the ac adapter without the battery. if the problem is the same, the motherboard is already defective.
Jun 11, 2010 | Acer Aspire 5315 Notebook
Acer aspire 5315 batt problem
Please run this unit on A/C only and see if it powers up like that. If it does not, then the A/C adapter is faulty and thus cannot charge your battery.
Service the battery by hitting it flat onto your hand palm or onto the back of your shoe and retry to see if it is charging.
May 25, 2010 | Acer Aspire 5315 Notebook
Acer aspire 5315 freezes only when plugged in to power adapter
The problem could be the CMOS battery
Please allow unit to be on power adapter overninght and see if the CMOS will be recharged anew. Another cause for a freeze could be interrupted update,so let the computer complete its updates or restore to before an update may have been interruped. The other possibity would be defective hardware.
Jan 06, 2010 | Acer Aspire 5315 Notebook
Acer Aspire 5315 won't power up. The AC adapter has a green light on it, so it appears to be getting power. The battery indicator light does not light up at all when I try to power it up. Do you think it...
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not help, try disassembling the laptop & re-seating its main components like the memory modules, hard disk drive, CD/DVD drive, etc.
Dec 11, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
I have an acer aspire 5920 and it will not power on. It stopped working while someone was using it. I've already taken out the battery and unplugged it, nothing worked.
sounds like the power adapter or the unit itself. hopefully, it's just the power adapter-- was there/is there a light on it that tells you its plugged in or charging the computer? is that light still on when you plug in the computer to charge it? if not, call acer for a new power adapter, it's usually free if you're under warranty. if it's on, you may be in trouble that the computer is dead-- maybe a fried motherboard. to replace a motherboard is probably 200 bucks, to get a new low-end laptop is 499.... at least in the US, I dont know where you are,
Feb 01, 2009 | Acer Aspire 5315 Notebook
My Aspire 5315 will not start
I actually contacted Acer by email for this and got a reply in less than a day.
Try the steps below for a power reset, to eliminate a hardware problem with your notebook:
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to www.acerpanam.com; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays. For out of warranty products please call 1-866-621-2237. Hours of operation are 7am-8pm CST, Mon-Fri, and Sat-Sun 8am-5pm CST excluding holidays.
Dec 17, 2008 | Acer Aspire 5315 Notebook
Acer Aspire One  PC Notebook Logo
273 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
