Mac OSX Canon Pixma MP 520-Keep getting error message,"The paper is jammed.Clear the paper,and press ok." I can't find any paper jams,and have looked allover the machine,opened up the cover,dusted all around,turned the printer on and off;and called Canon Tech support.All to no avail. All Canon could suggest is unplugging the machine.Then they suggested buying a new machine,or having it serviced.The machine is only a year old.This should not be happening
    President:
  • 987 Answers
A) Switch the printer OFF
b) Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
c) Keep pressing this four buttons for 10 seconds
d) Release the On/Off button (number 4) (Keeping pressing the others)
e) After a few seconds (when the printer go ON) you can release buttons 1, 2, 3
Notes:
1. Maybe step "c)" is not needed
2. This procedure was used when I refilled the Black cartridge -
try using the ColorCopy button instead of BlackCopy button (number 1)
if you refill Color cartridge.
3. Maybe there is no need for all the four buttons -
you can try 1 + 4, 2 + 4 or 3 + 4.
(or 1+2+4, 1+3+4, 2+3+4)
Posted on Apr 20, 2009
Alarm button flashes, check printer, press OK .Error 6A00 appears, Pixma MP 750
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Dec 14, 2009 | Canon PIXMA MP750 All-In-One InkJet...
I have a Canon MP 520 Pixma printer and getting error code 6000
There is got to be a paper Jam inside the printer OR
Look for something that might have stuck up the roller ..
Thanks
Fame !
May 02, 2009 | Office Equipment & Supplies
Message reads: the paper is jammed clear the paper and press OK
Even if a small piece of paper stuck inside the printer you ll get this msg.  So what you have to do is if you have a Air blower or vaccum cleaner blow air inside the printer,  If any piece of paper is stuck inside it will come out and you won't get that msg again.  Try this and sure it will work...!
Mar 18, 2009 | Office Equipment & Supplies
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
19 people viewed this question
k24674
jasbo
jasbo
