SOURCE: Unit will not restart and keep unit cold when camping in cold tem
freon contract in cold wheather
SOURCE: norcold n1095 not working on AC...works fine on LP
Yes. LP is direct heat to the exchanger. The thermistor operates through the control to the electric heater.
SOURCE: My RM-2611 refer freezer section works ok. The box
clean the coils and allow 24-48 hours unplug as you clean let me know..
SOURCE: not working on ac on propane freezer gets down to
There was ohm resistance there, but not a lot. After removing the heating element it only gets hot in about a 3" area of the tube/element. Transfer of heat was present but not a lot, you could touch it anywhere on the tube but in the 3" area. A typical hot water heater element either works or it doesn't meaning it it "open" but his has me baffled as I can't find any specs as to how many ohms it should read.
SOURCE: trying to purchase a heating element for a Dometic Dm2652
Try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673. there not a dealer just a service department, they might be able to help.
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
