Question about Kenwood KAC-749S Car Audio Amplifier
Wiring Diagram I have a Kenwood KAC-749S 500 W 4/3/2 amp and need a wiring diagram that I can understand. I have 4 speakers and a subwoofer.
  • 65 Answers
First, try looking here: If that helps, be sure to leave feedback or I don't get paid. Look all over the cruchfield page and you can find guides for every type of installation.
Posted on Oct 03, 2007
Need Wiring diagram for Kenwood amp #KAC-501
Installation instructions begin on page 9 of the manual.
Oct 16, 2012 | Kenwood Car Audio & Video
I have 3 Kenwood 12'inch subwoofers need to know how to wire them up to a Kenwood KAC-9105D
Follow the link and use the first diagram which illustrates wiring the subs to 2.66 ohms
Remember that that amp is one ohm stable so you will not be getting the most out of that amp with that subs set up. The subs will only see 650 to 850 watts each sub will only see about 215 - 275 watts a piece. Find out what the RMS wattage of your subs are each an determine if the wattage I mentioned above meets those requirements.
Sep 27, 2012 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Kenwood kac-749s amp power indicator flashing red. what does this mean and what can fix it?
Either there is a short in the in the amp or hopefully just the speakers or wires going to the amp. disconnect any speaker input output and turn your amp back on(you will only have power, ground, and remote wires plugged in at this time) and if the red protect light goes away, then there is a problem with the input/output speaker wires, this includes your RCA's. If it's still flashing red then there may be a stray wire shorting to the amp in the speaker outs, other than that your amp may be fried. By the way, if it works without any speakers connected, including RCA's try connecting one component speaker at a time starting with your RCA's(if using them), speaker in, then speaker outs. If it turns into protect mode, note which speaker/RCA it was and replace or repair the short.
Jul 11, 2011 | Kenwood Car Audio & Video
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
When i hooked the amp up the it would blink red right when i turn the stereio on
this can be caused by a short or a non constant current from your head unit to your remote power wire on your amplfier (your remote wire might be broken some where). Or your amp is losing ground. also check your speaker wiring and so on. has a subwoofer wiring diagram for all occasions.... make very sure you are wired properly this can be killing your amp causing the light to dim and so forth...
Dec 11, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
Hope this helps.
Sep 07, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
No wiring diagram for amp
+ red power to battery
- black negative cable to body/ground
rem blue remote wire that connects to blue wire
on the back of your cd deck
Jul 05, 2009 | Kenwood KAC-7203 Car Amp
That amplifier is only stable to 2 ohms.
You will only be able to use one Dual 4 ohm Subwoofer wired in parallel (all + to + on amp.... all - to - on amp.
This will yield a 2 ohm mono load.
It is impossible to wire (2) dual 4 ohm voicecoils to achieve a 2 ohm mono load.
If you're set on using both subwoofers - they will not be getting as much power from your amplifier with a 4 ohm load - but it is your only option.
SEE THIS LINK for the wiring diagram.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jul 02, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Wiring for kac-622 car audio amplifier
Jun 12, 2009 | Kenwood KAC-749S Car Audio Amplifier
Ok i basically have a kenwood kac-6404 amp and its a 2/3/4 channel i was wondering how i can alter them or switch it from 2 to 3 to 4
i guess there is no switch. its how you wire the outputs together to create 1 channel from 2 channels. consult the wiring guide that goes with your amp
May 15, 2008 | Kenwood Car Audio & Video
Kenwood KAC-749S Car Audio Amplifier Logo
1,196 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
