Question about Welding Tools
Need operator manual for Lencospot Mark II L 4000 spot welder
2 Suggested Answers
justjordy33
SOURCE: can't fine a operate-parts manual for a chicago arc 180 welder
I would go ahead and contact someone with <a href="http://www.suburbanweldingandsteel.com">chicago welding</a> they really know will be great.
Posted on Aug 02, 2012
How do you full choke a lincoln power arc 4000 welder/generator
Here is a copy of the engine operations from the manual.
Jul 04, 2016 | Lincoln Welding Tools
How do I operate Culligan 01011289?
That is a serial number NOT the model #. We need the model number to help you.
Example: Culligan Gold series, Silver, Medallist, Mark 100, etc.
Here is a link to help you find your model:
http://eculligan.com/service-manuals/manuals.php
RJH2O
Aug 06, 2014 | Culligan 34" Whole House Water Filter...
Code p1128 weak mixture lose power on inclines engine light on melts spark plugs vehicle hyundia accent 2001
Go to www.hmaservice.com and register your vehicle by VIN #..
you'll then have access to wiring diagrams, shop manuals,
service bulletins, illustrations, etc. To diagnose a 2000 or 2001 1.5L Accent Diagnostic Trouble Code (DTC) P1128 (FUEL SYSTEM LEAN -- PART LOAD), check the following:
  • Check the intake system for air leaks.
  • Check that the Mass Air Flow (MAF) Sensor (P/N 28164-22610) operation meets the specifications listed below. If the MAF sensor output is significantly lower than the reference value (10% or more), then replace the MAF sensor.
Table 1: Using the Hi-Scan Pro in the Hyundai Diagnostic Menus Current Data Screen TPS (%) 0
3.5
5.1
7.4
MAF (kg/h) 10
21
30
47
RPM IDLE
2000
3000
4000
Table 2: Using the Hi-Scan Pro in the OBD-II Menus Current Data Screen TPS (%) 0
3.5
5.1
7.4
MAF (g/h) 2.8
6
8.5
12.7
RPM IDLE
2000
3000
4000
WITH MANUAL TRANSMISSION
Table 3: Using the Hi-Scan Pro in the Hyundai Diagnostic Menus Current Data Screen TPS (%) 0
2.4
3.9
5.9
MAF (kg/h) 9.5
19.4
28.8
43
RPM IDLE
2000
3000
4000
Table 4: Using the Hi-Scan Pro in the OBD-II Menus Current Data Screen TPS (%) 0
2.4
3.9
5.9
MAF (g/h) 2.5
5.5
8
12
RPM IDLE
2000
3000
4000
Jun 26, 2011 | Hyundai Accent Cars & Trucks
B & O BeoMaster 4000 Tuner/Amplifier Operating Manual
Good morning, afternoon, evening or night; whatever time you are viewing this. Thank you for choosing FixYa to assist you with your problem. You want an owners manual for Bang & Olufsen's BeoMaster 4000 Tuner/Amplifer? Here ar some links that can help you obtain this.
http://beophile.com/?page_id=8253
http://www.beoworld.org/prod_details.asp?pid=346 (You have to sign up to become a member. Depends on how bad you need this manual.)
http://www.manuals-online.net/manuals?page=1&q=%22Beomaster+4000%22 (More links to websites that may have what you're looking for.
http://www.manualzone.com/ShowProductsForModel.do?model=M17238648 (Be prepared to pay if you decide to purchase one.)
Hope these links help. Thank you again for choosing FixYa as your one-stop solution spot for your problems. Be sure to visit our site again and have a good day, evening or night; whatever time of day you are viewing this.
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
MANUAL FOR A MAGNA SPOT 1500
To get a manual. Here is a link to the contact information for Magna spot welders by Motorguard. Hope this helps.
http://motorguard.com/contact.html
Mar 29, 2011 | MotorGuard Magna Spot 1500 Stud Welder...
I mounted the Canon 580EX II to my Canon 5D Mark II. When I using Manual Mode, I can't set the shutter speed more faster then 1/200 sec. Is this problem normal/limitation of it?
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
May 11, 2010 | Canon Speedlite 580EX II TTL Flash
We recently purchased a Brother EM530. Several of the keys either print the wrong character or do not print at all. We have reinstalled the Daisy wheel without success. Please advise. Rita Bolt City Of...
Turn the T/W on, mark the printwheel with a dab of white out, turn it on and off a few times if the mark dosen't come back to the same spot you have a broken homing pawl. If it comes bact to the same spot chech to see if you are int he proportional space setting for pitch or are in KB II.
Manuals are available @BROTHERINTERNATIONAL.COM click on support.
DickyO
Feb 25, 2010 | Brother EM-530 Typewriter
Need an operating manual for the century 80
Do a web search for lincolnelectric.com and look for the manual for this model.
Oct 12, 2009 | Lincoln Electric LE 83180 Century...
Welding Tools Logo
455 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
