Question about Lexmark Optra M410 Laser Printer
939 service system board; what it's mean.
IT IS GETTING A 939 SERVICE SYSTEM BOARD. I DON'T WHAT IT MEANS.
  • 41 Answers
First, make sure the printer power is off and remove the RIP board. When you turn the printer back on, the only option on the display will be to perform the test. Pressing the button next to that begins the test. The page that comes out should have just a lot of lines printed on it. If this does not print or is somehow messed up, then the problem must be with the engine board. If this page prints and looks OK, then it is probably the RIP board that should be replaced. Please keep in mind that this test cannot be considered to be conclusive but it can be used to make an educated guess about which component is failing.
When the printer beeps five times and the operator panel is blank, there are several things that might cause this. It could be the op panel, the op panel cable, the Low Voltage Power Supply (LVPS), or the engine board. To find out which component is failing, the printer would need to be checked out by a service technician and the failing component replaced by him/her.
Posted on Jul 13, 2009
What does the icon mean on the dash board on a Saab 2003 93 it's a pic with a car and a slippery road an a line through it
It means the electronic stability control system has a problem and the system is now disabled.
You need to take it to dealer service to have them identify the cause.
Mar 10, 2016 | Saab Cars & Trucks
Why won't my system go to service mode
If youre out at the equipment controller and push the button to switch from auto to service and it doesnt work, it usually means you need a new board. Theres a reset button on the outdoor controller, look to make sure it wasnt pressed and got stuck. If that looks ok, then the board should be replaced, buy an iaqualink instead of your replacement board, it is backwards compatible, meaning all of your existing controllers will still work, but it gives you internet/iphone/android control capability as well.
Jul 24, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
What to do Error E677
hello i will tell you what error means and how to fix the problem but you will need the service manual to help you
1. E677 error means that "The communication between the printer board and the machine has a fault."
2. Check the connection between the
printer board and the PDL I/F
board and the system motherboard.
Is any of the pins bent or otherwise
not normal?
3. If this not helped you must replace the printer board
You can download the service manual for ir400 from the below link it will save u $$$:
http://goo.gl/bFmfmN
good luck
Sep 11, 2013 | Canon imageRUNNER 400 Printer
My tv does not turn on any more and the power light just blinks red twice i have a 50" panasonic plasma model number thp50s10p
A blinking light on your TV means it is on face mode because one of your parts is shorted out and the TV is protecting the other parts. I don't have the service manual for this TV but on the older Panasonics 2 blinks poited to the D board. You can do a search online for a service manual for that TV therir are a few retailers selling it. The D board is also know and the Logic board which is located under the signal board. On This TV I belive the logic and signal boards are just one board. You can get parts for this TV at www.interliquidparts.com
Jun 13, 2011 | Televison & Video
Switches on for afew seconds then red light goes yellow then switches off?
Means there is a system board error that needs to be serviced by sony. Usually means the board needs to be re flowed
Mar 23, 2011 | Sony PlayStation® 3 (60 GB) Console
T644 won't print - message says "900.43 Service RIP Software" - What does that mean??
It means the RIP board is bad. It's under the left side cover. I think the board is around 100.00 and easy to replace. Steven 805-520-3003
May 13, 2010 | Lexmark T644 Laser Printer
Computer turns on but nothing is dispalyed
You say the PC turns on... does this mean that it goes through POST (u hear those beeps etc)? This means that you have power but no apparently no video.
Test for VIDEO in the most basic form
Power up PC and see if u can access the BIOS (F2). If u can access the BIOS then it means your video card works.
If u cannot access the BIOS, it means you have a more severe problem and may have to change the system board to resolve it.
PLEASE NOTE
If you are actually getting NO POWER (meaning that there is no post and no indication of power) then it is a different story altogether. U're looking at a new power supply or new system board if it's integrated on the board and cannot be replaced.
Mar 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
What does service engine soon mean -exactly?
the service engine soon light means that a fault has occurred in the engine control electronics or the emission system controls, and in your case the transmission will also set the light, when this light is on one or more of the following codes will be stored in the on board computers memory. follow the link below for a list of GM codes for your OBD 2 (On board diagnostics generation 2) electronic engine management system.
http://westersgarage.eidnet.org/obd2.doc
Feb 26, 2009 | 2000 Buick Regal
Lexmark Optra M412
error 939 means --
RIP Communications Lost
Controller EngineCommunications Lost
The controller board and the engine board cannot
communicate with one another.
Solution --
POR several times
Check each board
for secure ground.
Replace the assys
in the following
order
1. Controller Bd
2. Engine Board
3. Intterconnect
  Board
Dec 12, 2008 | Lexmark Optra M412 Laser Printer
OSD screen lock
The OSD is controlled by the video card board (logic board)
It is information stored on the eprom, not something you can just get to. It has to be programmed.
To gain access to the OSD Service Menu from a user service point you normally access it via a series of buttons on the control panel. Holding several buttons at once in a set combination that is particular to that brand, or even that individual series of monitor.
OSD just means "On Screen Display" the menu system and the service menu are the OSD.
Apr 21, 2008 | Computers & Internet
Lexmark Optra M410 Laser Printer Logo
1,567 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
