Question about Kitchen Ranges
I replaced the baking element on my oven and it still does not get hot (Model # JPB25WY2WW)
  • texr Apr 20, 2009
    I checked wires and all are connected and nothing broken. I wiggled all connections that go to the bottom element and still it did not get hot. The broiler element has always worked. The circuit board has a # 9809 CPC 94 V. Do you think it may be burned out?
  • texr Apr 20, 2009
    Mr Smith: Did you get my last comment?
    Brigadier General:
  • 8,619 Answers
Hi
Check for the wiring between the control panel of your oven and the bake element. Also check for relay on the circuit board. This issue arises mostly because of the wiring between the control board and the bake element. Also tell me whether the broil element is working or not?
Are you getting any error codes as well on your Range?
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 20, 2009
  • Rylee Smith
    Rylee Smith Apr 20, 2009
    If the wiring is fine then its the control board which is faulty. Check for the relay on the control board, it will look somewhat like this---
    Wiring of the relay is like this---
    1 - Disconnect power
    2 - Remove the cover panel
    3 - Install new relay on the main back ( don't remove the defective old relay )
    4 - Disconnect wire L2 from the TRO relay and marrette it to the orange wire of the new relay.
    5 - Disconnect wire H1 from the TRO relay and marrette it to the red wire of the new relay.
    6 - Disconnect wire H2 from the TRO relay and marrette it to the black wire of the new relay.
    7 - Reinstall the back panel and reconnect power to the range.
    Also test the selector switch if its faulty.
    Thanks
    Rylee
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Nu-Vu oven will not reach bakeing tempature?
HELLO IM A OVEN TECH AND SEEMS THAT YOU MAY HAVE A FAULTY ELEMENT DEPENDING ON THE MODEL YOU MAY HAVE TWOO ELEMENTS ,ONE IS GONE ,
Jul 10, 2008 | Nu-Vu NUV-MDO11 Stackable Deck Oven 1...
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
