Question about Samsung HL-R6167W 61" HDTV
2 in gray bar only on one side.
This is a issue not a function of the TV. I was told by the folks who sold me the TV that my warranty is up and a tech could be sent out but I can't afford to do that right now. He also mention that it's been common for something that is taped (I don't know what) to come loose and throw some stuff off. Does anyone have any pictures of this fix and if indeed that is the problem.
  • bock289 Aug 13, 2008
    My 56" in Samsung has the same "gray shadow strip on one side" problem talked about all over the web, I guess its the "light tunel". My set is 22 months old. There is a class action suit set up already if you want to follow that.
    Anybody have a do it yourself fix to cut down on repair cost?
    Champion:
  • 217 Answers
Sounds like the light tunnel
Posted on Jul 20, 2008
SOURCE:
There are 6" wide gray bars on each side ot the TV
The grey bars signal that the source image is originally in 4:3 format - if you are using a box of some kind get in its menu and change the format from there to 16:9. The black bars appear when a 16:9 image is sent to a 4:3 format in Letterbox mode - leave it like that or the Pan and Scan mode will chop the sides.
Jul 20, 2011 | Panasonic Viera TH-42PX80U Plasma TV
50 gal GE PowerVent Water Heater, about 1 every 2 weeks we get an error message and NO hot water, we were told by the Warranty Tech people that we have to set the mode to vacation and then back again...???...
Your water heater is under warranty?
And tech folks are telling you that you have to 'reset' the water heater.
And the tech folks seem aware of the product defect, but don't offer a permanent fix.
That's ridiculous.
You shouldn't have to reset the MODE or do any other thing to that water heater for many years.
50 gallon power vent model cost a lot of money.
And you got a defective product.
And the tech people know it.
That's certainly not an installation issue, or a homeowner issue, that is a product issue.
The manufacturer is responsible.
Read the warranty papers and find out what the warranty says.
Look for the word 'defect' in the warranty paper
Document when the problem started and what you were told.
If you bought the water heater from Home Depot, it's time to contact them about a defective product.
And let Home Depot know what the warrant says about defect.
A small claims action against Home Depot will give you satisfaction.
Small claims court will want to see your stack of paperwork that shows how much trouble you went through to get a functioning and dependable water heater.
As far as fixing the water heater, it sounds like a professional plumber would be a good bet at this point.
Frankly, I would buy another heater and roll the defective one out of the way.
Bradford White, AO Smith manufacture and sell water heaters through plumbers.
Once these unit are installed, the warranty is provided by the installer.
Dec 23, 2010 | Water Heaters
Gentlemen; We purchased a 32 inch hygh def TV app 3 years ago. We had an issue with a burned out 32 inch model and had a certified repair tech come up to our home and had the main board replaced in I...
Please note that we are not affiliated with any company. We are a bunch of independent consultants with hands on experience at fixing stuff. However if you can get me the make and model of the tv along with country of residence I can get you the contact info of the customer service department so that you can get it replaced.
Oct 31, 2010 | Televison & Video
Toshiba 46RV525U are JUNK!
The LCD panel is defective. They are expensive. Call customer service and they may extend the warranty for you if you complain enough.
May 27, 2010 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Gray bars
Hi, you can removed this bar by using the picture size function in you menu this is du to the signal
you receive in your tv;if your tv got a full hd signal
choose the 16:9 picture format the bar will disapear
if you dont have 16:9 signal that normal but you can choose full screen mode it should gone , that is 4:3
format extend it to ful screen mode.
good luck and have a nice day.
Mar 13, 2010 | Televison & Video
Viore 52' TV randomly shuts off. front lights blink then stop.
I am having the same problem with my PRT50V24D shutting off and blinking lights. After going to viore.com and calling the number listed, I got recording to call another number. When got rep on line I was told it is made by Samsung, Called their tech support and was told that sounds like power problem or bulb getting ready to go. Also if outside of warranty will have to call repair man to see what's wrong. I will have a repair man out next week and will post his results here. Most likely it's the same issue. This is the tech support number for Samsung 1-888-697-2247. Good Luck man. Matt
Dec 05, 2008 | Televison & Video
Image issue on Sony DCR HC62 Handycam
This actually occurs on playback here is a snapshot of the screen and the gray bars.
Nov 14, 2008 | Cameras
TV wont turn on
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Feb 16, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi model WT-A42 MADE IN 2002
You can restore the function of the front panel buttons by pressing and holding the MENU button on the front panel
for more than 8 seconds. You may have to reset the button lock in the menu to reactivate or deactivate.
Hope this helps!
Bill
Dec 09, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi ws-65813
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get a tech says cant repair it this one does,its helpful to u if u have it under the warranty or protection agreement
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Samsung HL-R6167W 61" HDTV Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
