Question about Milwaukee 0730-22 V28 6-1/2" Circular Saw Kit
Replacing the cord on a Milwaukee 3/8s drill
I cannot get the hot and neutral wires out of the trigger? How does one remove the wires from said trigger?? There are no screws or clips? The ground wire had a screw. The power tool repair shops charge $35.00 to do the task.
  • 10,865 Answers
Troubleshooting milwaukee magnum hammer drill half inch 5370-1 672 b no power. Cord continuity is good
The only things that would cause this are a burnt out trigger switch or the motor brushes are worn out.
Sep 06, 2016 | Milwaukee Drills
How do i troubleshoot a milwaukee right angle drill trigger
Take care with that, Edward. These Care and Operating Instructions may help... http://documents.milwaukeetool.com/58-12-1561.pdf
Feb 07, 2015 | Milwaukee Drills
I want to repair cable on a milwaukee hammer drill 5392-1
If you mean the cord you can find the part number by going to milwaukeetool.com and you will need the serial number for the correct one. Or you can also go to ereplacementparts.com. You will need to solder the wire ends to push into the swiitch. To release the old cord straighten one leg of a paper clip and insert next to the wire and gently pull out the old cord. UNPLUG tool first and make note of where the wires came from. The Milwaukee site also has a wiring diagram that you can download. Let me know if you need more assistance.
Mar 13, 2012 | Milwaukee Tool Drills
I have a Milwaukee Hammer drill #5370-1, serial #672D 5044 60047. The drill stopped working and I suspected worn brushes. Now that I have taken it apart and found the brushes were not worn (and I found...
The brushes are usually replaceable from outside the drill. Make sure each spring is properly tensioned. Make sure the electrical outlet is live by trying a working lamp or other item. Pull the trigger full on and wiggle the cord where it goes into the plug--if the tool turns on intermittently, suspect a bad cord connection at the plug. Just replace the plug after cutting the cord back an inch or so. You can test the speed control by a temporary jumper across the module which should allow the tool to run full speed. Make sure the reversing switch is ok. Hope this helps!
Jan 06, 2011 | Garden
Replacing brushes and are they part of the trigger
depending on the date code, the brushes might not be replaceable. I suggest going to milwaukeetool.com and typing in your model number and under schematics find the one with the date code of your tool or get back to me with the code and I will research further, I looked at 3 breakdowns and one had replaceable brushes, and finally no they are not part of the trigger
Dec 21, 2010 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
Intermittent power when I pull trigger. I thought it was the brushes but I opened it up and there are no brushes. Can I assume it's the switch? Is it possible to replace it?
Hold the trigger down and wiggle the cord at the plug and at the tool, see if you can get it to take off by doing that. If you can, its a cord. The 0200-20 has brushes, unless this was posted in the wrong section, in which case I will need your model and serial number to help any further.
Dec 07, 2010 | Milwaukee 0200 20 Drill 3/8 1200 Magnum
When replacing cord on black & decker 7190 type 1 electric drill i dropped the drill one of the wires pulled free and im unable to visibly tell how it is to be rewired correctly need diagram displaying...
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
Jul 02, 2010 | Drills
When hammer drilling after drilling a few holes it stops then starts then stops then starts etc.#5370-1 magnum .i don't believe it is the cord
check the trigger switch inside the gun , a few small screws in the casing will have to be unscrewed then take the gun in half and check the trigger switch connections and possibly replace the switch I have had this problem before with no obvious signs of wear or un connected connections but then i replaced the trigger switch and it worked fine
Aug 21, 2009 | Milwaukee Drills
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
I need to change the cord on my 9392 Milwaukee Drill. The trigger does not have any screws and, I cannot not see how to change the cord out. The ground wire is attached to a screw connector.
On the trigger switch, if you look really closely you will see that there are clips inside where the wires go in. If you use a jewelers flat screwdriver or other narrow flat instrument, you can push the clip back enough to release the wire.
If the replacement cord doesn't have clips on the ends of the wires, make sure that you tin (apply solder) to the ends of the new wires before inserting them into the trigger. This is needed to keep the individual strands from being pushed everywhere and causing a short, and stiffens the end, making it easier to insert.
If you need further assistance, let me know.
If this was helpful for you, please rate the solution.
Apr 20, 2009 | Milwaukee Tool Drills
Milwaukee 0730-22 V28 6-1/2" Circular Saw Kit Logo
224 people viewed this question
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
