Question about Cobra 148 GTL 120-Channels Base CB Radio
148 gtl 5pin
Wires insrde mic jack came unhooked which 1 goes where
    Guru:
  • 773 Answers
Looking from inside the radio at the mic jack, with the nub down. Starting from the left is pin 1, pin 2, pin 3, pin 4, and pin 5.
here is the colors that should be attached to each.
1 is white.
2 is sheild.
3 is black.
4 is red.
5 is blue.
Hope this helps. Take care in soldering. It is easier to reach the pins if you remove the 4 screws that hold the face plate on. Be careful not to pull another wire from somewhere.
Posted on May 03, 2009
Cobra 142 GTL feeback audio
put on a different mic and see if it still happens.I am going to attempt to draw an insert so if it works follow it if it doesn't I'll explain it.
this wire is the audio on the inside of mic
-------------------------------X-------(4700ohm 1/4 w res) ----X---------
.001 .001
this wire is the shield
-------------------------------X-------------------------------------X----------
at the point marked with X take two .001 capasitors and wire them from one wire to the other. this should make your squeal go away.
Apr 16, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
148 mic wiring white d104
five pin /4 pin? (white D-104?)
five pin= 1-audio,2-shield,3-RX,4-comm,5-TX
4 pin=1-shield-comm,2-audio,3-TX,4-RX
Jan 03, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
When i keyup my d104 mic on cober 148 gtl ihear feedback squeal.but the d104 work good cobera 2000 gtl
try to keep the mic away from the radio speaker.check to see if its turned up to high.check your mic gain to make sure its like 1/2 open.If these fail then you could solder two 0.001 ceramic disc capacitors from the audio to the shield wires about 3" apart.then on the audio wire in between the 2 caps solder a 4700 ohm 1/4 w resistor.this should work.
Nov 09, 2013 | Midland 1001Z 40-Channels Base CB Radio
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
Mar 14, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I need to know if it's possible to convert the cobra 148 gtl 5 pin mic jack to 4 pin mic jack.
5 pin to 4 pin as follows, from the Cobra website.
1.->2 Audio
2.->1 Shield and common
3.->4 RX
4.->also goes to pin 1
5.->3 TX
Apr 21, 2010 | Radio Communications
Need to change mic jack . wires came unhooked which wire goes where ?
If it is a 5 pin then..
1 is white.
2 is sheild.
3 is black.
4 is red.
5 is blue.
Here is a 4 pin explanation:
Again looking from inside the radio, with the nub down. Starting from the left, Pin 1, Pin 2, Pin 3, Pin 4.
Pin 1 is red.
Pin 2 is white.
Pin 3 is blue.
Pin 4 is black.
Apr 20, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
5 pin mic
All "older", "real" or "desirable" Cobra 148 GTLs came with side-mounted 5 pin microphone sockets. For wiring information, see...
http://www.offroaders.com/info/tech-corner/reading/mic-wiring.htm
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
164 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
