Question about Refrigerators
Will it damage old upright freezer to unplug it when not in use--can't afford new one even though it would save money in the long run.
I have an old upright freezer which I need to use a few months out of the year. I have NO money to purchase a new one although I know it would pay for itself in the long run. Will it damage the freezer to leave it unplugged during the months that I do not need it?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 75 Answers
It will not hurt it at all. Clean it out real well including the all around the door seal. Be sure to prop the door open enough to allow air circulation so that mold and mildew does not begin to grow.
If you have children or children have access to the freezer, BEWARE!!! children have been known to play or hide inside these things. THIMK! SUFFACATION! Danger!Danger!
Posted on Apr 20, 2009
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
I live in Winnipeg, Manitoba. I have an old Kenmore upright freezer. I would like to leave it in my unheated patio over the winter. Should I leave it plugged in, or can I unplug it and just watch the...
Leave it plugged in. It won't over freeze. If the outside air is cold then it won't need to run as much to bring down the temp-nature is doing that. So when the weather gets warm it will run to keep everything frozen. Hope this helps. Google burdfrenzy
Nov 25, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Upright frigidaire commercial freezer has no power, we had a flood in the basement. I unplugged it now the the water is gone, it will not power back on. Is there a reset button or did the moror fry from...
Water damage is hard to remove because it could have goten to the electrical parts: motor, compressor, timer, etc.. while it was still running. you need a volt meter to test these parts out no reset sorry
if it was running with water then toss it out...
sorry
call a service guy and he will tell you the same for $80!!! save your money
you can try to raise your freezwer off the ground when you get your new one...
hope this was helpful
Mar 28, 2010 | Freezers
I have a Kenmore Upright Freezer. I need to
I unplug mine and let it take several days. You break a line or punch a hole in a line and the freezer will be ruined. Just let it thaw out on its own to prevent damage.
Feb 10, 2010 | Freezers
Kenmore upright freezer no digtal light no motor running
if it is an electronic control freezer then the electronic control sounds as though it has failed if there is no digital read out
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
13 months old Kenmore compressor very hot.
lacdoi,
huuum At your service!
You said,
The warranty just ran out, Sears came out told me needs a control board ($210 for just labor to replace) not sure about part price. I though a new freezer is about twice his labor and parts, so I sent him away minus $65.
I did some troubleshooting today, pull the plug for 2 days. Plug it in, temp alarm goes on all the time. Turn alarm off, left the freezer running for 4hrs.
Not cold at all, some cool air. Fan is on, compressor is on (can hear humming noise and is vibrating). Compressor is very hot to the touch, could burn finger.
Should I call Sears again, wonder how much to fix all the problem? Or just give up, look for another brand new one (not Kenmore).
MY ADVICE:
Sounds like a big repair bill and multiple problems
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliance are so much more efficient today that they can save you a lot of money in energy!!!!
Replace it.
You will be fine
Bless You huuum
Please give me the best rating for my fine advice before you sign off.
Thank you
Sep 17, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer not freezing
Hello jannette859,
huuum at your service
You said,
freezer was working fine had to unplug it due to evacuation, now it doesn't freeze, is there any reset buttons? i didn't turn the temp selector to the off position before unplugging
Try turning off the temp. switch off.
Then plug it in and turn the temp on!
this may reset it.
Repeat one more time and let me know ho it went!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Bless You huuum
Please give me the best rating at fixya .com before you sign off.
Thank You
Sep 15, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer - top shelf frosted over -- poor cooling through rest of freezer
Hi yadak,
Happy to help.
You may need a new door seal.
But they are not easy to put on properly
and I would not recommend spending a lot of money on a ten year old freezer!
the new ones are much more energy efficient and will save you a lot of money!
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
