Question about HP Pavilion dv8235nr Notebook
XP won't load onto hard drive.
DV8235NR. 160GB Hitachi hard drive. XP media Edition 2005 system. SATA drive. In BIOS the disk checking confirms good hard drive and S.M.A.R.T enable. Set the laptop to start up with MC 2005 disk in CD ROM. After post goes to CD. WINDOWS IS CONFIGURING YOUR SYSTEM. After that it sometimes loads windows and then freezes, sometimes it goes to the recovery screen and stops, sometimes it freezes at the configuring system One time it loaded windows and went to restart but BSOD appears quickly before it restarted.I've tried enabling SATA and disabling SATA in the BIOS (BIOS is F23)I put a pony drive in the USB and configured bios to start that first.I get the windows did not start screen choose SAFE. WHen I run SAFE I get a quick BSOD and then it restarts. The BSOD is too quick to read the problem. I think It is some sort of hardware problem, but the BIOS is so limited in what can be disconnected. Any thoughts?
    Scholar:
  • 74 Answers
Start the computer and press the f8 key as if to start in sage mode, but select the "Disable system reboot on error" (not sure of the exact wording on that). Then when the BSOD hits it will stay there so you can get the error number and message.
Alot of times these are memory errors so I would also suggest that you download a program called memtest 86. It is a small ISO file that will create a bootable cd to test the memory. You can get it from:
http://www.memtest86.com/download.html
Hope this helps
Posted on Apr 30, 2009
How to format/install SATA 2TB hard drive (BARRACUDA) in Gateway GT5098E, Win XP Media Center Edition 2005?
Windows XP doesn't support SATA. You will need to use a program such as Nlite to integrate sata drivers into a new Windows XP disc. Once you have a disc with sata drivers just boot to the disc and follow the prompts to format the drive.
Jan 04, 2013 | Gateway "HITACHI DESKSTAR 0S02861 2TB...
Bios reconizes new hd drive but xp pro does not
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
I have replaced the hard drive on my HP G5000 laptop with a Samsung HM161GI drive. All tests OK on BIOS diagnostics, but Windows XP Setup says no hard disk is installed??
This happens because the hard disk is natively a SATA and XP doesn't have a generic SATA driver so from its point of view the disk is not there. You will need to go into the BIOS and set the SATA connection to use the legacy/IDE mode.
May 16, 2011 | Samsung Spinpoint M7E HM161GI 160GB 5400...
How to configure bios to read sata hard disk problem
Are you sure it is a bios issue? In many cases you need to load additional Sata drivers during Windows installation to support sata disks.
Oct 08, 2009 | HP Pavilion dv8235nr Notebook
Installation of windows XP
preachw996 has it... you must enable the SATA drive you want to install XP onto as your 1st IDE DRIVE/DEVICE (ie. you are telling BIOS to dummy a SATA drive in to the 1st IDE position).
Only then will you be able to recognise the drive as a boot device.
This is done in BIOS.
Mar 27, 2009 | Microsoft Windows XP Media Center Edition...
SEAGATE HARD DISK DRIVE PROBLEM...
just remove the jumper settings of the HDD like this one.;
choose the master without a jumper.
let me know
Oct 04, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
See all HP Pavilion dv8235nr Notebook Questions
Computers & Internet Logo
110 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
