Question about Sony Video Cameras
Sony video camera will not record but will play previous taped t
New batteries new tape cannot see subject through vewier to record but i can put in a recorders tape and see it ok on play but will not record
TO REPLACE THE CCD ASSEMBLY. SOME MODELS ARE COVERED BY SONY WARRANTY EVEN AFTER WARRANTY PERIOD, BECOUSE OF FACTORY FAULTY CCD-S -ASK A SONY REPAIR CENTRE OR LOGIN TO THEIR WESITE GOOD LUCK: KOPASZ
Posted on Apr 21, 2009
My Sony Handycam DCR-HC26 started giving me C:31:23 error ''Reinsert the cassette'' when I try to record on a new Sony tape. I am however able play back a previously recorded Sony tape.
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Mar 18, 2010 | Sony Video Cameras
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
The sound is not working when trying to record on a new tape or do a new recording, but works on other tapes that have been previously recorded
There are 2 heads in the recorder. One for reading (playing) and the other for writing (recording). 1st try cleaning these heads
using a Squab (Q tip) with a alcohol based cleaning solution (Radio Shack). Always rub the squab on the head in the direction the tape would follow, not perpendicular.
Jul 31, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Sony Hi-8 plays new recorded video buy not playback
Are they PAL or NTSC tapes ? They may not be compatible with your new equipment.
Jun 13, 2017 | Sony Handycam CCD-TRV40 Camcorder
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
Sony handy cam
If your Sony tells you it is recording yet on playback there is nothing there other than a blank screen, I had this problem and this is how I solved it.
1. Clean the heads two or three times with head cleaning kit
2. Leave the tape door open, with tape out or in, and warm the camera up for about 2 hours minimum.
3. Put in a previously recorded tape and see if it will display that film. If not, repeat 1 and 2. Persevere.
4. Once Stage 3 works (you might have a few "dirty" lines on it for a few seconds, and it is playing normally, try recording.
This worked for me. The heads were dirty and the camera cold but I persevered and thankfully it is OK (but for how long?)
Hope this helps. It seems to be rooted around dirty heads and coldness.
Jan 03, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Jvc camcorder
Your camera has failure of the CCD image sensor. Please contact JVC Service for free repair, if your camera model falls in their list.
Aug 19, 2008 | JVC GR-D53 Mini DV Digital Camcorder
Video Cameras Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
