Question about EliteGroup P4M800PRO-M Motherboard
Auto power off problem
I have a elitegroup P4M800PRO-M motherboard and since installing it my system will not poweroff automatically once windows is shut down.
  • Alison Terry Sep 21, 2007
    They were set as per the installation manual
    Did not check then as the reset and power off work fine. Could this still be the problem even though they are working ok?
ACPI is set on in the CMOS and there is no option in control panel power options to turn off PC to power down. I am using XP
Posted on Sep 21, 2007
    President:
  • 2,961 Answers
You have either got the power and reset connectors the wrong way round fro the front panel, or you have not enabled ACPI in the advanced cmos settings to allow the board to support shutdown by Windows. Also check in the power options in control panel and ensure that when you click turn off the pc is instructed to power down.
Posted on Sep 20, 2007
  • andrew pester
    andrew pester Sep 21, 2007
    and what about checking the correct + and - pin connection to the motherboard?
SOURCE:
My motherboard (p4m800pro-m v2) burned out and it seems the motherboard has been discontinued. It is absolutely impossible to find. Is there a recommended replacement or upgrade available?
I would suggest you buy a new board which will support your existing CPU and RAM, that way you will save $ on those items. Just do some shopping at FRYS.COM or TIGERDIRECT.COM
Getting it to work with your existing windows installation may be the challenge.
I would boot up on the windows cd, go through the installation till it says looking for existing windows... Then choose repair existing windows installation. This way it will install the initial drivers for the new chipset and video.
Feb 02, 2011 | EliteGroup P4M800PRO-M V2.0 Motherboard
Onboard sound card does not seem to be working can anolther card be purchased for this board and if so what?
cmi 8738 is a cheap solution. first disable the on board ac97audio in bios setup,then install the pci card into the pci slot. usually the system can find the sound card and auto install driver , if not, setup the driver manully.
Dec 18, 2010 | EliteGroup P4M800PRO-M Motherboard
How to reset this motherboard? P4M800PRO-M2 (V2.0) from elitegroup.thanks
remove power lead and internal battery for 5 mins then replace all and it will be reset to manufacturer date and settings
Oct 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Need audio driver for intel 845 gl
Download it from here:
http://www.intel.com/support/chipsets/sb/CS-009236.htm
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | EliteGroup P4M800PRO-M478 Motherboard
Hanging while installing windows Xp
Make sure your cpu clock settings are correct...(don't try and overclock until the o/s is installed). also be sure to use the proper ram
Apr 26, 2009 | EliteGroup P4M800PRO-M478 Motherboard
I switched out the power supply on an elitegroup p4m800pro-m. I was originally using a 300w and now using a 680w, but now my computer wont even start up. Any input?
I believe that your power supply may be bad. If it is new , send it back. I have had that high pitched sound before and it usually indicates a capasitor going or gone bad.
Feb 18, 2009 | EliteGroup P4M800PRO-M Motherboard
Please give me a copy of installer of my motherboard?
you can download the drivers at : http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=673&CategoryID=1&DetailName=Feature&MenuID=44&LanID=9
Jan 06, 2009 | EliteGroup P4M800PRO-M Motherboard
EliteGroup P4M800PRO-M Motherboard Logo
152 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
