When reformatting it takes me to the DOS start up to start in safe mode, safe command prompt mode and start up normally as if the computer was just shut off and not shut down properly
I am reformattin a hp laptop and it keeps taking me to the DOS start up options are start in safe mode safe mode command prompt and start normally
james klgr
  • 362 Answers
SOURCE: Laptop not starting up in Windows
you are having a bios problem you need to look at your owners manual and see what key you have to hit during startup to enter bios, some you push delete, some F!, some F8, but push the appropiate key then use the motherboard manual to check the settings of your bios, all these should have come with your machine new. if bios is configured correctly and it still dont boot while in bios disable your CPU internal cache, make sure your HDD S.M.A.R.T. is enabled, and make sure that your hard drive is listed as detected in intergrated periphals , if its name and size isnt listed select detect and hit enter if it dont detect your hard drive could be bad or another problem if it does then you sre ready to use the system to trouble shoot itself. just follow the directions on the screen.
Posted on Dec 31, 2007
  • 131 Answers
SOURCE: hp pavillion trying to boot from dos mode
my pc is writting Disk boot failure, insert seystem disk and press enter. pls help.
Posted on Apr 30, 2008
SOURCE: My toshiba laptop m30 satellite will not let
if u reinstall in ur operating system.
Posted on May 04, 2009
Jubert
  • 249 Answers
SOURCE: computer seems to be in a loop when turned on
What you are having there is a problem with the booting up of windows. most likely a corruption. The best thing to do here is to have your computer taken to a local technician or a friend who knows about computers. Have your hard drive files recovered by connecting your hard drive to their computers. Then after that you could either try to use your windows xp cd to do a repair installation (However its not a guarantee that you will be able to recover your files with this step.) or to have a full Operating System reinstallation. Hope this helps.
Posted on May 28, 2009
myjosh007
  • 530 Answers
SOURCE: Laptop won't startup properly
Friend that problem if cause of not shutting down properly.just select start safe mode as it recovers it will restore late back to the proper one
Posted on Jun 05, 2009
Display only in safe mode
It is possible that your computer is not able to start up (normally), e.g. problem with your Windows XP, Windows 7, etc. ... e.g. you see a blinking cursor at the top left corner of your (blank) blue screen.
If this is the case, you can try to repair your disk first ... in save mode, get to a DOS prompt, i.e. >
You may see options/commands (at the DOS > prompt) by typing HELP. One of the programs that attempts to repair the disk is CHKDSK. Type at the > prompt: CHKDSK /? to see the options
Then, run the CHKDSK command to repair the boot disk.
After completing the chkdsk, type EXIT (to go back to Windows). If necessary, shut down and power up again and see if the boot disk has been repaired.
In the worst case, you may have to restore your disk from backup, or boot from a back-up (boot disk / CD) to fix the boot disk problem. But first try to save/store all your (personal) files (while in SAFE mode) before you reformat the disk and re-install the operating system (from an installation / boot CD disk)
Mar 04, 2014 | HP Pavilion F1703 17" LCD Monitor
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
When i turn on my computer it starts to boot up then goes to microsoft windows xp.the next screen is a blu one thats says avg install path :c:\program files\avg\avg2012
See if you can uninstall AVG by booting up into Safe Mode.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Uninstall AVG then reboot and see if you are ok. Download and install Microsoft Security Essentials as your antivirus program.
If you still get the blue screen, Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 09, 2012 | MSI K8MM-V Motherboard
Configuring updates screen
Try booting up in Safe Mode and see what happens.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it boots up ok, then do a restart into your normal windows mode.
Try running the check disk utility.
Jun 08, 2012 | Computers & Internet
I have a gateway kav60 that wont start past the boot menu, it wont start in any mode(safe mode, normal, or safe with prompt). i have nothing hooked up to it, all i did was install new updates from...
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 25, 2012 | Acer Aspire One PC Notebook
My acer netbook (winxp) won't load after the mouse cursor appeared
Sounds like you need to run the check disk utiltity but since you don't have a CD Drive, you're up the creek without a paddle. try booting up into Safe Mode and if you get there successfully reboot and see if the normal mode works, if not you can uninstall Microsoft Security Essential in Safe mode. Or you can use System Restore to restore back to a point (date and time) when the system was working ok. Click Start/Programs/Accessories/System Tools/System Restore and select a restore point before you loaded Security Essentials. In Windows 7 just click Start then type System Restore in the search box above the start then look at the returned results and click System Restore.
System Restore does not lose any of your data, documents, music, pictures, videos or programs (unless the programs was installed after the date and time you selected).
To get into safe mode follow the steps below:
You can try to get to a dos command prompt or you can see if the system will allow you to boot in Safe Mode to get to the dos command prompt.
May 12, 2012 | Computers & Internet
An unexpected i/o error has occurred
Boot into Safe Mode and see if it will allow you to run a System Restore.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If the check disk utility can't fix the problem you'll need to reinstall windows.
Apr 07, 2012 | Computers & Internet
My Toshiba laptop won't start. When I turn it on a command line itnerface appears saying that Windows won't start sucessfully and it may be due to a recent hardware or software change. It gives me 5...
Go to the safe mode option then once there go to start-run-then type in MSCONFIG then go to system recovery then go to recovery for an earlier time. This will reset your Windows to an earlier time you may be able to salvage it without having to re-install the operating system. F8 also will bring you to "Safe Mode" if not do it through the Dos command screen. If this does not work then you might consider re-installing Windows again. John
Jan 22, 2011 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
