Question about Home
Correct tank to bowl gasket for Orion toilet
Orion toilet tank to bowl gasket was given toilet have tried several universal part and all leak. HELP:
  • 170 Answers
I would change out the flush valve itself...it will come with the right gasket....it won't cost anywhere near the price of a new toilet...and it will save you time in the long run..good luck and.thanks for rating my effort....the fang.
Posted on May 01, 2009
How do i fix a leak from the cistern to the toilet bowl
There are bolts attaching the tank to the bowl check to see if they are correvtly tightened after you check to see if the gasket is properly seated.
Dec 25, 2014 | Home
Toilet leak
You have to remove the tank and replace the tank gasket and the tank to bowl bolts and gaskets as well, do not reuse them, they will leak again.
Jul 25, 2014 | Bemis Home
Toilet tank to bowl small leak
You need to replace the tank to bowl nuts, washers, and gaskets as well as the flush valve gasket. One word of caution. When installing the new bolts to hold the tank in, place a rubber gasket under the washer inside the tank, and also one on each bolt under the washer underneath the tank. If you omit the one under the tank you may end up cracking the tank when you tighten it down.
Jan 16, 2014 | American Standard Cadet 3 Right Height...
Orion toilet, the tank to bowl gasket leaks
turn off the water,, flush the toilet ,, using a rag or paper towels sop up the remaining water in the tank, ( if you hold the flush valve down more will exit the tank) remove the water inlet tube, remove the 2 or 3 hold down bolts that have a slotted screw head inside the tank, and a nut on the underside of the bowl, use care in lifting the tank off the bowl section, as they are normally a matched pair and most aren't interchangeable, on the underside of the tank you will see the bottom of where the flapper attaches,, at that point will be the gasket that needs replacing, remove it, and install the new one, reverse this order to re assemble,, NOTE, you don't have to tighten the tank bolt very much,, snug is better than over tightening, the tank will crack if you over tighten the tank back on the bowl, so use care in this step, I always replace the tank bolts at the same time,
Sep 10, 2011 | Home
Memoirs leaking from seal between tank & bowl. Just replaced the gasket and still leaking
In 2008 I bought the Memoirs model that Lowe's was selling. I've had multiple tank/bowl gasket leak problems. When I went to get a replacement gasket this weekend, Kohler had changed the style of the tank/bowl gasket assembly in the current Memoirs model that Lowes sells. I wonder if this is because the old gasket assembly is known to be defective and prone to leaking?
When I called Kohler, it took two customer service associated, but I was granted a WHOLE NEW TOILET with the new style of tank/bowl gasket assembly. I just had to have the receipt for the (3 yrs ago) purchase. Kohler e-mailed a letter for a replacement toilet within about 15 minutes and before the end of the day, I had a whole new toilet in my bathroom.
I'm not a contractor. Just an average homeowner, so I can't say for sure that the old style (large, black, plastic rectangle on the bottom of the tank and a rather thin gasket ring) was defective or not. (At first Kohler offered only a replacement tank, but after hearing the number of times both I *and* plumbers have replaced the gasket, they did authorize the replacement of the entire toilet.)
Apr 10, 2011 | Kohler Home
My mother has a Jacuzzi Toilet and the only number she can give me is the number stamped on the inside of the Tank as BN30 Bn31. Can you tell from that what the model is. I'm trying to get a gasket...
*********** has a Jacuzzi Perfecta.
This came in two models... one with a round bowl, the other with an elongated bowl.
Both of them use the BN30 BN31 tank.
If you have trouble tracking down a gasket, you might try using plumbers' putty.
Be aware, though, that there have been reports of the back of these tanks cracking. Check the tank to ensure that the leakage is coming from the gasketed surface, and not from a crack.
Mar 03, 2011 | Jacuzzi Home
New Glacier Bay Toilet leaks between tank and bowl. I have taken off the bowl and re-attached several times and the bowl leaks at the factory installed gasket every time, one side or the other. It appears...
Hello, W/D here.
The gasket you are talking about is hard to get into the hole properly. It tends to want to "bunch up" on one side or the other. The easiest way that I know of to install it is to place the gasket on the tank and then to wet the seal and wiggle the tank as you set the tank onto the back of the bowl. Water based jelly also works (better). Just apply sparingly if using the jelly; place a little around the seal, and a little around the molded socket of the bowl, and place the tank on the bowl. wiggle the tank back and forth lightly, then align the tank with the bowl and insert the bolts. If you have a mirror and flashlight, use them to help inspect your work as you go.
Best regards, --W/D--
Feb 28, 2011 | Home
I have a small leakage problem that seems to be coming from under the toilet set. I had the seal replaced, and have checked all the obvious places under the water tank. Plumber I had doesn't seem to be...
have plumber recheck tank to bowl gasket make sure it is correct size also make sure flush valve is correct part not a universal some tanks are thick or thin porclean may extend to far out of tank bottoming out in bowl connection also proper bolt tighting is essential
Nov 05, 2010 | Toto Drake ADA Compliant Toilet with...
The tank leaks where attached to bowl. Are there any universal gaskets I can use?
you can buy a servicing kit from plumbers merchants which includes the necessary big rubber seal when fitted make sure the 2 retaining plastic or wing nuts on cistern are tightened evenly
Mar 12, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Water leaks from tank to bowl till water level in the tank is jus
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Aug 03, 2009 | American Standard 2002.014 - Champion4...
Home Logo
862 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
