Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV-48WP34 - Convergence issue, voltage readings?
To recap my my tv has wavy grren lines across the top 1/3 of the screen, and it will not converge. http://www.fixya.com/support/t193778-convergence_green_lines I have the ICs (stk392-150)and replacements for the out of range resitors. Before I reassemble I wanted to verify the voltage. The 10-pin plug coming off the power board has 2 29.2v pins, and 2 pins with -32.9v. Should all the readings be the same? there is also a pin with -12.8v. Also the -33v pin values seem to climb slowly; after 5-10 minutes the voltage on both was -34.5. (29.2 pins are constant). I am not sure what I should be looking for, do these values sound problematic? If so what do I need to do to fix it. Thanks Again
    Problem Solver:
  • 13 Answers
This is the wrong power pack for this model STK 392 - 110 without using the right powerpack it's called make work day.
Posted on Oct 24, 2007
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
JVC Model no: AV-48WP34 Projection Problems
OK, problem seems in convergence section of TV and can be confirmed by testing voltage supply as mentioned in schematics.
You can download service manual copy from Manual Zone for small fee and it has schematics, exploded views. board location, part numbers info.
Let me know if you need further help.
Thanks.
May 07, 2009 | JVC Televison & Video
Double picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 31, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP34 convergence issue
Chances are there are other resistors open
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence green lines
Closely inspect the board for poor solder connections. Also someitmes the resistors will not show any signs of being bad even though they are open. It is wise to measure them but you need to disconnect the convergence yoke plugs to ge a good reading.
Sep 04, 2007 | JVC AV-48WP30 48" Rear Projection...
Tv screen waves and is double
No. You have bad convergence output ic;s and probably at least 1 burnt resistor. This liely will have to be reconvergec in the servcie menu after the aprts are changed.
Jul 12, 2007 | JVC AV-56WP30 56" Rear Projection...
Convergence no good on lower corners and upper screen
I'm assuming you used STK392-110 for a replacement. You could use STK392-150 for greater reliability and don't forget a good heat sink compound. (VERY IMPORTANT). What it sounds like is something even the best of techs battle. You probably didn't buy original Sanyo STK's but instead got a couple of the JApan knock-offs. Might I suggest you carefully replace them again and this time order them from B&D Electronics, Bdent.com on the net. You are assured of getting quality OEM replacements that way... We've had a bad batch that purchasing ordered quite some time ago and 2 out of the 14 ordered worked.. The rest were DOA (dead on arrival). Good Luck Bill
Apr 28, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
191 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
