Question about HP DesignJet 450c InkJet Printer
Catridge light and Data aresolid orange when machine turned on
Nothing is trying to be printed at time i turned it on. Ready light is solid green. I can get rid of data light by pressing cancel button. When i do that the ready light turns off. The cartridge light is now blinking a solid orange!
Please help!
  • 53 Answers
This is a problem, sorry to say. The Mark Encoder is not being detected. In laymans terms this means that you need a new carrage. Part Number is C4713-60039. You also need to check on the condition of your belt at the same time. Is there somebody in your area that can do the work or are you capable ?
Dave
Posted on Jul 01, 2009
Kyocera not feeding paper.
Open paper tray, locate the feed roller (small rubbery wheel) and moisten a cloth. Gently clean the roller to remove build up of paper dust from it.
Also worth using is some "anti static foam cleanser" on the cloth to help deep clean the rollers, or the pre-moistened "Screen wipes"
Also check there is nothing blocking hte paper path, remove paper cassette, and toner catridge (and drum if I recall correctly) and see if you can feed a sheet of paper MANUALLY from tray up into the "imaging chamber" where the toner lives. If this feels too stiff, there could be an obstruction in the way, fragment of paper scrunched up after a REAL jam, or fault sensor arm.
If you find something and can remove it, reassemble, and test
Dec 10, 2014 | Kyocera FS-4000DN Laser Printer
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
Getting blinking green ready/data light but will not print
Pls refix the catridge. May be your printer catridge will not fix properly.
Nov 09, 2009 | Dell 1720dn Laser Printer
Both green and orange lights blinking. Printer
Try deleting all ready to print documents, restarting the printer and then re-booting the computer. Somebody in there is confused.
If that doesn't work, check your documentation on how to print a test page, if it will print then the problem is which the application otherwise re-install the printer.
Oct 09, 2009 | Castelle LANpress Jr. MP (66298601-040)...
Error E14 while refill the catridge and installed
E14 The Ink cartridges whose destination are wrong.
Ae the cartridges the correct ones and are they in the correct carriage?
Try this:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thank you.
Yboyandrei
Aug 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Green horseshoe light is continually lit
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
Jul 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP DesignJet 450c InkJet Printer Logo
423 people viewed this question
Seeker5211
Seeker5211
