Question about Brother HL 1440 Laser Printer
Printer not printing
My printer will not print it goes through the steps and then it will have an error, I delete and try again and it will do a few pages. The ready is not on, I have taken out the ink cartilage and reinstalled. Help!!!!!
    Problem Solver:
Which lights are blinking? what is the error?
Posted on Oct 29, 2007
My printer Epson t13 has a general error it says ''delete all print jobs and turn off the printer and remove any foreign objects from inside the printer. after a few minutes turn the printer back on. But...
Good morning to you!
It might be worth trying to go to the "print page" on your computer and remove the print queue, then there is nothing waiting to be printed. Then disconnect the printer for 30 sec. or so and restart your computer. Give it a try, good luck,
kolbrun
May 26, 2014 | Office Equipment & Supplies
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
General error L200, what is solution? I try to turn off and switch again...It Error again..
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. but not working printer.
Sep 30, 2012 | Epson L200 Original Continuous Ink Tank...
Page is not printing completely
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
However, if you're trying print but the print status screen only goes partial, try to follow the steps below to fix the issue:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh. Try print again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Oct 13, 2011 | Lexmark X1150 All-In-One InkJet Printer
My printer does not print. I do not get any message either. What could be wrong? The toner lamp is illuminated, but the level should not be "too" low. Brother HL-2030.
Most of the time, this is caused by memory failure or when print command isn't responding. Suppose if you give a print command few hours back and it's wasn't printed successful, then the document to be printed should be in the print queue list. So, firstly check the print queue documents, and delete all the queues. in case you can't delete them, follow these steps, Start - Printers and Faxes - Double click your Printer Icon - Click on the Printer Tab - Select Cancel All Documents - Ok and close the dialog box and the printers and faxes window (note that your printer should be kept power On and connected to the Pc) Wait for few minutes and restart your system while you Power Off the printer. When the system boots up, also power on the printer and check if there's still the Print Queue. Now you can try printing documents if there's none, or you'd need to follow the same steps again. There are some more ways, but this solves most of the problem. So give it a try and let me know the result. Remember that your printer is connected properly to the Pc. Good luck.
May 18, 2010 | Brother HL-2040 Laser Printer
It won't print from my computer .It lets me set page size ect. and looks like it is a go but the printer does nothing. I can scan from the printer to the computer. It just won't print the pictures from my...
Hi, There are several things that makes printer go to not working condition. You will have to follow few steps before trying to print again. Believing you are using Microsoft Operating System, open Printers and Faxes from Control Panel. Now right click on the printer and click on "Properties" that is being used by you. Try to print a test page. If you get a print, it means there is some glitch with your printer preferences. You can set it to the defaults. You can look for the same by going to different tabs. I am not able to write specifically as I am unaware of the printer and OS being used by you.
If you do not get test print, double click on the printer's icon in Printers and Faxes of Control Panel and see if there is any pending queue there. If there is one, remove all pending tasks starting from the bottom of the list. In most cases you will not able to delete the top print queue. In this case, click Start Menu > Run. In the Run box type "services.msc" without quotes. Look for "Print Spooler" and select the service. Restart the service with the link provided on the top left corner of the screen. Now once again try to delete the print queue that you were not able to delete. This time you will be able to delete it. Once you have performed all the above said troubleshooting steps, try to print a test page again. In most case these troubleshooting steps resolves the issue. Now check if the printer is set to default. If not, right click on installed printer icon and click on "Set default printer".
If printer is still not printing, try to uninstall printer and re-install it using its installation disk that is provided by printer's manufacturer.
Cheers!
Feb 28, 2010 | Office Equipment & Supplies
HP5610 all in one, error message oxd0620230, reset power. I reset power, but it will not print, starts printing then I get the same message again.
This happens to me when my kids try to print something and it gets stuck in the print log and I can't delete it...I am not a cpu guru by any means, but I found these steps easy to do and it works....
1. control panel>admin tools>services> right click on Print spooler in list> press stop (leave this window open).
2. go to Cdrive>windows>system32>spool>printers>select all>delete
3. go back to print spooler in list from #1 and right click start
4. restart computer
There is almost always a "flash" off the page that the kids tried to print that "hangs" up the printer. I hope this helps.
Jun 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Brother HL 1440 Laser Printer Logo
64 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
