Starlogic 17'' as dual display not clear
I'm using my Starlogic 17'' LCD attached to a laptop (HP Paviliion dv600)as a dual display. I run Vista.
The colors are all off and distorted. I have tried every adjustment on the NVIDIA panel and cannot improve the visibility. The Starlogic monitor picture is perfect if I set it up as a clone of the laptop, but not as a dual screen so I believe the monitor is fine on its own.
Any suggestions?
    Problem Solver:
  • 18 Answers
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Posted on Apr 20, 2009
Monitor displays out of range
reduce the screen resolution and then connect the monitor
Aug 12, 2014 | Star Logic Starlogic 17" Tft Lcd Monitor...
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
17" starlogic monitor model M19BNK serial M9B49CKVoo4584
blown capacitors on the vga board or the resolution for the display adapter is set too high for the monitor reduce the resolution in safe mode and you should be ok, if not then the bad capacitors are in need of being repalced
Sep 17, 2008 | Star Logic 17" LCD Monitor
Dual Monitor Color/Brightness Differences
Correct the resoulution is not the same. Also you are using 2 monitors and using the system to power these great displays. Just dont hook up a docking station. The picture gets really bad..
Feb 13, 2008 | Computers & Internet
Problems with monitor
Are sure you plug into the right socket jack.
Try plugging different socket and listen.
Jan 19, 2008 | Star Logic 17" LCD Monitor
Red screen?
If the vga cable nicely connected may be the logic card in the LCD.
Jan 06, 2008 | Star Logic 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
