Cannon mf 3240 mystery error
Paper jam open cover but there is no jam
  • 469 Answers
Paper jams occur in two ways, a physical jam, this is where there is a mechanical jam of some sort. the second is a timing jam, the paper has not reached a given point in a specified period of time.
I suspect you have the second problem, what you need to check is this.
Is the paper loaded correctly? Did you fan the paper to break the production bonds? Is it good quality paper.
on the top sheet of paper in the paper tray, mark it with an X , a happy face or some thing to show it is your page. Then press copy, did it try to pick up the paper. If it did not try at all, there may be a problem with the paper feed drive system.
If it tried but failed, the feed tires are likely dirty or worn our, you can try cleaning them with some isopropal alcohol (available at drug stores) and a soft cloth if yo can reach them. remove the paper tray, or st least all of the paper, you should be able to see a set of rollers in the middle of the feed section. clean these and retry the machine
Hope this is of some help.
Ed
Posted on Apr 20, 2009
Were is the paper feed drive system
Posted on Apr 27, 2009
Always paper jam error on my cannon 3530
Check for a paper fragment at either end inside the printer chamber or underneath the paper feed roller cover plates. Anything that holds a paper feed sensor arm open will give you paper feed errors, and they can be remarkably small.
May 14, 2015 | Cannon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
My cannon MP160 pixma keeps telling me there is a paper jam when there is no paper in it, it will copy and give me color tests printed out but if i try to print a doc. It says E# paper jam
Hello thanks for using fixya
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My Printer is Laser, Cannon LBP3000, while printing paper jammed into the roller, computer gave instruction that "open the top cover of the printer and remove the paper by pulling". But after...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Canon LASER SHOT LBP-3000 Printer
MY PRINTER SAYS PAPER JAM BUT HERE IS NO PAPER IN IT ???
Look for any traces of tiny paper shreds that might got stuck between the rollers. That might be causing the paper jam error. If you could open the back cover, check from there also as those paper shreds might also blocking the sensor.
Sep 18, 2009 | Canon L120 Fax Laser Printer
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
164 people viewed this question
jasbo
jasbo
