Question about Goodman Heating & Cooling
I have a Goodman GPD075-3 REV B gas heater that tries to come on but shuts down within 4-5 seconds. After the gas burners come on they shut off. The exghust blower is running and also the house blower is on. What is causing the unit to shut off? Is it the flame sensor or something else?
SOURCE: GKS91155DXAD Not finishing cycle
Check the heat anticipator setting on the thermostat if its a mercury type thermostat. It may not match the proper amp draw. Take the cover off and it is a little metal lever. Try different adjustments to see which are better. If its a digital thermostat it may have an internal setting. There are several other possible reasons this could happen but that would be the most likely. for more infor on self diagnosis or the like check out my fave website Ra-Jac Air Conditioners and Heaters TX for repair information.
PS: If its a new installation it should have a one year warantee so call back the person who put it in. If you did it yourself be extremely careful gas furnaces can be dangerous. You might want a service person to check the job out for safety hazards. Good Luck with it.
Posted on Feb 29, 2008
SOURCE: Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Posted on Jan 06, 2009
  • 56 Answers
SOURCE: ruud silhouette #UHDG-07EAUER won't heat house
Cleaning the flame sensor has nothing to do with blower motor not turning on. You either one of the following problems 1 bad cap for motor. 2 bad motor. 3 bad limit on blower housing or 4 a bad board. You will need a volt meter to check for these problems. Try seeing if the fans runs with unit of and fan switch turned to on. Also does motor hummmm. Is motor cage free ( can check by manually turning) If motor doesnt humm and the cage is free wheeling then you will need to find out if you have power going to the motor. If you find out that you do then you will need to change blower motor. If you do not have power then you will need to check limit with continuity tester on volt meter. If that checks fine only 1 thing can be wrong and that is the board.
Posted on Feb 16, 2009
  • 2976 Answers
SOURCE: gas heater won't work
Which flame sensor did he replace? The pilot flame or the plenum temp. sensor.
Posted on Aug 10, 2009
  • 1015 Answers
SOURCE: gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Posted on Dec 21, 2009
Testimonial: "I did not expect such a quick response. These are hard times for us and we really appreciate your help. Thankyou for sharing your expertise."
Goodman gas heater model GUE080-4 . pilot lighs , but furnace will not . Electronic pilot lights & stays on for about 1 min, than shuts off seems main gas relay not switching on.need manual
Check roll out switches located around burner compartment.
there is a small square button between the wire terminals press firmly down on it to rest switches. If this solves the problem have the furnace cleaned and checked by a professional HVAC technician.
Bob
Jan 06, 2015 | Goodman Heating & Cooling
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
My Goodman heater has a problem igniting at times
Hi, I would have to assume your igniter is weak or has a crack in it. Do you see glow from the igniter every time? There is a flame sensor that looks for flame after the gas comes on and it will lockout after three tries, if the flame came on and shut back down every time, it would be problem with that.
Jan 08, 2010 | Goodman Heating & Cooling
Model #GMPN100-4 Goodman furnace. Vent fan
The sequence of events for furnace operation is -
Fan purge for 30-45 seconds. During this time, a pressure switch is actuated by the running of the purge fan, proving the control board the purge fan is running.
After purge and purge prove, the hot surface ignition and or spark begins. After a few second delay, the gas valve will open. The control board then monitors for flame prove through another sensor located near the burners. If there is no flame within 3-5 seconds, the gas valve closes. It will repeat this process, usually 3 times, before it shuts the system down, which requires a power down of the system to reset.
I have seen trash get into the hose between the purge blower and the purge switch. But you could be having other problems.
Dec 17, 2009 | Goodman Heating & Cooling
Goodman furnace GSM100-4 model has constant ligt blinking. Will fire all burners and in few seconds shut off. Help
for what ever reason, your shutting down on high temp
4 things to check
1 the filter
2. your fan, is it comming on....... to circulate the heat.
3. your hi temp thermostat is bad and needs to be replaced.... it should be a sqaure with two wires
you can just ohm it out to know sometimes orange but it differs some
4. above your fan are the coils, ar5e they clean and free of restriction
Oct 28, 2009 | Goodman GDS80904BNA Open Flame Heater
GOODMAN GAS FURNACE. IGNITOR GLOWS, GAS FIRES FOR 3-4 SECONDS THEN SHUTS OFF..CYCLES OVER AND OVER. SOMETIMES IT STAYS ON...THEN SHUTS OFF BEFORE TEMPERATURE GETS UP TO THE STAT SETTING...
I suspect that the flame is not traveling to all the burners within a given time so the flame sensor is shuting down the gas valve. Clean out the flame rail where the flame travels and carefully brush off the flame rod with an old tooth brush.
Oct 19, 2009 | Goodman GMS90703BXA Heater
Goodman furnace seems to be cycling too often. Burner not staying on long enough to put warm air into system. Burner quits after a few seconds then repeats.
dIf the burners are only staying on for about 5 seconds, you proably hav e a dirty flame sensor. Watch the burners light, the glow plug will light one end of the burners, in front of the last burner to light the will be a small thin rod, this rod must sense the flame or the gas will be shut down. Take a piece of steel wool and gently cleqan the rod.
Oct 11, 2009 | Goodman GDS80904BNA Open Flame Heater
Goodman gmp125-5 burners ignite, then shut off after about 5 sec
One of two problems are happening here, your flame sensor is bad, your thermo pile or thermo couple is bad, or last is that the cap on the flue is blocking the exhaust from escaping
Feb 08, 2009 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
279 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
