Question about Lexmark X2500 All-In-One Printer
Paper jam on Lexmark X2500. Have tried numerous solutions
Cannot stop the paper from jamming. Have tried numerous solutions??
  • pkremer May 11, 2010
    Lexmark 2500
    How do you open the access panel.
    Found three screws in back
    two clips under retractable paper tray/catcher
    looks like it should open upwards but is sescured by something unseen.
    Genius:
  • 2,035 Answers
Please try this step if it still fails then its the problem with hardware of printer,
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Apr 25, 2009
Keeps saying paper jam
yo a paper jam is funny. you must not be afraid to try things. this is what you have to do: open all doors of your printer and look for the jammed paper, even look for tonned pieces of paper
Oct 06, 2010 | Lexmark X2500 All-In-One Printer
Hi, my paper has jammed inside the printer and i am unable to pull it out
Please check this article which gives you a detailed information of how to get the paper jam cleared.
http://www.lexmark.com/publications/pdfs/lexmarkc720/eng/jams.pdf
Thanks
Jan 15, 2010 | Lexmark X2500 All-In-One Printer
I am having problems with printer paper not loading correctly and its causing a paper jam when i attempt to print
Try wiping the rollers with alcohol. I find if they are too dirty, they make the printer return a paper jam error.
Dec 14, 2009 | Lexmark X2500 All-In-One Printer
Paper keeps jamming. seems tp be pulling to one side slightly.
Usually that is a sign of an object in between the rollers.
Check for paper or other foreign body. It will be located on the side that dragged.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Lexmark X2500 All-In-One Printer
My x2500 printer states "PAPER JAM"; there is no paper jam
Hello there:
i have the same printer with the same thing too but i sent mine in and come to find out that the paper carrier carrage is worn out and needed to be replaced it would cost about 70 dollars to get it fixed hope that this helps some
best regards mike
Aug 01, 2009 | Lexmark X2500 All-In-One Printer
My printer will not completely roll paper through the printer
Maybe the cartridges are in slightly crooked. Take them out and put them back in. Make sure there is no paper or any other obstruction around there and try again. :)
Mar 05, 2009 | Lexmark X2500 All-In-One Printer
Printer always jams
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Lexmark X2500 All-In-One Printer
Printer jams
I has a problem like this too. What I did is I checked the paper feeder by putting my hand in it (while turned off) and I found a ballpen cap.
Lexmark X2500 All-In-One Printer Logo
512 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
