Question about Leviton (102-5G108-RW5)
I don't know how to make network cable.
What I don't understand is how to arrange the colored wires when making a crossover or straight-throu cable.
Thanks
    President:
  • 1,996 Answers
Here are a couple of links that make it pretty clear, and have nice pictures:
click here and click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 20, 2009
Color code for wiring plugin
I'd like to help you. Can you clarify? What 'wiring plugin' are we talking about? Presumably, you're trying to plug a wire of some kind into something. There are different color codes for almost every different kind of cable; without knowing which one you are asking about, your question is impossible to answer.
What wire are we talking about? What is this wire meant to connect to (on BOTH ends)?
This is just a guess, but since this is in the 'router' section, you may be asking about network cables. I've attached an image showing the wiring diagram for both normal and crossover cables:
Additional information and network-cable wiring pinouts can be found here:
How to Make Category 5 Cat 5E Patch Cable
Best of Luck!
May 31, 2015 | Computers & Internet
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
I want to network two pc with windows xp using crossover cable,, how do i do it step by step pls.
Connect two computers using a crossover cable
If you need to connect two computers but you don't have access to a network and can't set up an ad hoc network, you can use an Ethernet crossover cable to create a direct cable connection.
Generally speaking, a crossover cable is constructed by reversing ("crossing over") the order of the wires inside so that it can connect two computers directly. A crossover cable looks almost exactly like a regular Ethernet cable (a "straight-through" cable), so make sure you have a crossover cable before following these steps.
Before buying a crossover cable, check your network adapter. Some newer network adapters automatically "cross over" when they detect that they are connected directly to another network adapter using a regular Ethernet cable.
To connect two computers with a crossover cable
This works best if both computers are running this version of Windows.
Plug each end of the crossover cable into a network port on the back of each computer.
On one of the computers that is running this version of Windows, do the following:
Open Network and Sharing Center by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Network and Sharing Center.
In the network map at the top of Network and Sharing Center, double-click the Unidentified network? icon. (If you have more than one network, this icon will be labeled Multiple networks.)
If network discovery and file sharing are turned off, in Network, click the Information bar containing the following message: "Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change...," and then click Turn on network discovery and file sharing. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Network discovery and file sharing dialog box, select one of the following options:
No, make the network that I am connected to a private network
Yes, turn on network discovery and file sharing for all public networks
The first option is usually the best choice because it only affects the network that you are connected to.
Notes
Networks created with crossover cables are automatically set up as "Public place" networks, which means that network discovery, file sharing, and printer sharing are off by default.
For Gigabit Ethernet or token ring networks, you will need a slightly different kind of crossover cable. For more information, contact a cable manufacturer.
Icons for both computers should now be visible in the Network window. Double-click each computer icon to share printers and other resources.
Note
If one of the computers is running Windows XP, it can take some time for that computer to appear in the Network window. You might need to move both computers to the same workgroup. You can do that by changing the workgroup on either computer. To change a workgroup, see Join or create a workgroup. You might also need to turn on file and printer sharing on the computer running Windows XP.
Hope this help!
Sep 06, 2011 | Pine Technology Motherboard Xfx Nforce...
I HAVE 30 TP LINK (TL-SF1008D) SWITCHES ATTACH WITH MY SERVER .IF ANY SWITCH WILL OFF OR DEAD HOW CAN I FIND THEM THAT WHICH SWITCH HAVE PROBLEM. IS THERE ANY SOFTWERE TO GET ALL SWICTHS MAC ADDRESSES OR...
A switch should not have bad ports, its just a basic level device not much higher than a hub. Make sure you are using straight through cables to connect pc's to it. you can tell if it is a straight through most of the time by looking at the colors from left to right. (see picture) this will not be the case 99% of the time but sometimes a switch or router will come with one for connecting to other switches (which is what crossovers are made to do.
nathan_f.gifNote the colors and check to see that both cables have the same. if one is different then it is a crossover (it crosses wires so that similar devices can connect together.) Hope this helps, good luck with your switch.
May 08, 2011 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
How to attach cat 6 cable to rj-45 jack
Good day..You should have knowledge about the color coding for cat-6 cable termination. Its called "termination" computer term.if it is a straight-throw use this color code:RJ45 must face at you when you arrange the wire colors..WOrange,Orange,WGreen,Blue,WBlue,Green, WBrown,Brown..(W=White). Then use a Crimping Tool to crimp it.Flat that twisted wires before you insert to rj45. Hope you are okey with this. Ask me if problems occured. Mastergani
Mar 17, 2010 | Computers & Internet
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
I just want to know how to arrange color for cross over cable
Here's a web page that shows you the color arrangement for a crossover:
http://www.littlewhitedog.com/content-8.html
The same info will apply to jacks.
Also, adapters are available to do the crossover for you, no need for wiring:
http://kb.wisc.edu/showroom/page.php?id=3095
Jul 10, 2009 | Leviton (102-5G108-RW5)
Standard cat5 wiring doesn't match philips rj45 flush mount
Are you looking for cat5 straight through cable or crossover??
option 1 (straight through)
each pin correspond to the other end in the same spot.
If all the cables are colored the same then you need an ohm meter to identify them.
Option 2: (crossover)
Pin 1 correspond to pin 3
Pin 2 correpond to pin 6
Pin 3 to Pin 1
Pin 6 to Pin 2
or you can go to (for schematics):
http://www.duxcw.com/digest/Howto/network/cable/cable5.htm
Nov 21, 2008 | Computers & Internet
To connect a unit with a computer 1km away..
There are easier ways of doing this. If you simply want to extend the length of the Cat 5-e cable they make simple connectors which do so. You must make sure the cable is a STRAIGHT SHOT cable and not a crossover cable though. A wire tester would work to look at the configuration but you can look very closely to the color coordination inside the connector and figure out which configuration the cable is. If the colors are int he same order on both sides then you have a straight shot cable.
Mar 19, 2008 | PC Chips (M925G) Motherboard
Pc's say a network cable is unplugged
First, NO, crossover cables are for connecting LIKE devices.. you need a Straight Thru cable for connecting 2 PCs to a switch.. So, if you are using Crossovers, then you are getting the correct results (cable unplugged). Replace with the proper cables, and it should see the network fine..
Also,
As this ProCurve HP 408 is 10/100 auto sensing, you should be able to automate speed and duplex within your NICs conifiguration...
Happy Holdiays!
Dec 22, 2007 | HP ProCurve 408 Networking Switch
Leviton (102-5G108-RW5) Logo
161 people viewed this question
Top Leviton Computers & Internet Experts
ashburton
Michael Galve
Michael Galve
george  peters
george peters
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
