Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Rear wheels are locked on snapper riding lawnmower.
On my old Snapper riding lawnmower, the wheels won't turn when in neutral gear while trying to push it and when its cranked, makes a growling sound when put in gear. Has a new drive disc on it, but seems to be damaging it. When rear of mower is jacked up wheels turn freely.
  • Anonymous May 22, 2009
    same as above but its a craftsman mower
SOURCE: Husqvarna Riding Mower won't turn over
It could be a combination of things... it could be a loose earth lead from your ignitor pack or your timing could be out, check your key way that will be in the centre part of the magneto.. too see if its ok will need to remove the magneto to see the key way if its brocken it will not fire up and sometimes will back frie through carb if its bad enough, also check your gap between the ignitor pack and magneto should be around the .20 too .25mm by feeler guage...
Jay QLD AUS
Posted on Feb 24, 2009
  • 653 Answers
SOURCE: snapper rear engine riding mower clutch
It is time to replace the driven wheel. When you flip the mower up on the back end (after closing the vent on the top of the fuel cap), the driven wheel is the disc that has rubber on the outer edge that rides on the silvery disc that comes off the end of the motor. The last time I bought one was about 7 years ago, at which time it cost me about $7.85. I would expect it to be around $11-12 these days.
Posted on Apr 07, 2009
  • 33 Answers
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
Posted on May 02, 2009
wadembly
  • 448 Answers
SOURCE: How to replace lower deck spindle bearing on my
take the deck off or take the belt off of pulley there is a nut on top of pulley loosen nut with a brass hammer hammer it down & it should drop the spindle out to replace bearings
Posted on Jul 09, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Snapper rear engine riding mower. Mod#28085S
If one goes to the starter, the other has to come from a 12 volt source, either ignition switch or battery
Posted on Oct 04, 2009
Replace friction wheel Snapper 3317523BVE (7800254) - Snapper 33" Rear-Engine Rider
Warren, Could not find your particular model, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HowTo Replace Your Disc Drive Friction Disc Wheel
Riding Lawnmower doesn go foward Drive Disc Replacement
snapper clutch repair for beginers friction disc
Snapper Friction Drive Modification
May 13, 2016 | Snapper Garden
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
Starter on snapper re110 not always working
does it crank no start/hard to restart
or
no crank
BIG difference
Oct 20, 2014 | Snapper RE110 28 inch 11.5 HP Rear Engine...
Twin bag grass collector for a 42inch
Ken - if you locate the Model number on the lawnmower, you can look up the bags here: Snapper Parts
Feb 26, 2014 | Snapper 28"/33" Twin Bag Grass Collector...
I have a 33 inch Snapper RE riding mower with a 14 HP Koehler engine. I had to store furniture in my garage so the lawn mower sat out in the rain. Now it won't start. It only makes a clicking noise and...
Whilst it was in for the solenoid did they change the spark plug? If not remove it and give it a good clean and check the gap at the end to ensure it is correct. It should tell you what it should be in the manual.
My old lawnmower is a nightmare to start so I try and warm it up before starting.
Jan 15, 2013 | Garden
Snapper rear riding mower won't move while in gear
yes your looking at the problem easy to change close the vent on the fuel cap remove the battery and lift it up and stand it on the rear bumper tubes (thats what there there for) after replacing you might need to move the links for the cable up near the pedal
Jul 11, 2012 | Garden
I have a old Snapper riding mower with an 8hp Briggs and Stratton engine, The other day it wouldn't crank so I changed the switch and the solenoid, the battery was fully charged and it still won't...
make sure thers power going into the starter
if there is then see if the starter is siezed, try turning the fly gear, but not just up against the flywheel but try turning the starter backwards to see if it moves
Jul 29, 2011 | Garden
Snapper push lawnmower worked fine last summer thru Sept. took it out today and can't get it to crank. Any suggestions to crank lawnmower after it sit up for 6 months?
Your carburator has old fuel that has turned to "varnish" essentially. It must be removed and cleaned. Next year, run the fuel all the way out so there is none left in it to turn to varnish.
Apr 15, 2010 | Garden
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
519 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
