Question about Dell Dimension 2400 PC Desktop
No response from my system upon power up except for fan
On power up only fans turn on desktop was not in use for 3 months
  • Dick
    Dick May 11, 2010
    Open the case and reseat the memory modules and the video card. If that does not fix it you'll need a technician to look at it.
  • 17 Answers
Open up the case and unplug everythng except for these items :
Power Supply
Motherboard
CPU
Memory
(video card if no onboard video)
and see if it comes on, if it does, then add each hardware part one at a time to find the bad one.
If it still doesnt respond, unplug all power and remove the CMOS Battery on the Motherboard. Then let it sit for 5 minutes. Then try it again.
If that still doesnt fix the problem then you will have to get some new or "Known to be good" hardware to swap out the parts above.
If your using a new Power Supply & Memory and the only thing else thats still plugged in is the Motherboard & CPU and still no no screen, then odds are its the Motherboard...
Hope this helps, when the problem is down to this basic level, the only thing you can do is try other parts doing the "trial and error" aproch.
Posted on Apr 20, 2009
My pc was working properly when I turned it off. Upon returning I powered up my pc (HP 805n) but it will not turn on. The green light in the back of the pc is steady, but no response. I've own the pc...
to trouble shoot,
open case and disconnect all cables except power supply.
if the computer starts up okay, then shut down and connect the cd-rom then startup. if that's okay then connect any other cables . if any one of the parts are defective you will find the stinker.
if the computer still won't go, try another power supply/
if that's okay, then the board might be bad
Aug 03, 2017 | HP Pavilion a805n (PS519AA) PC Desktop
The computer will not turn. tested power supply and seems to by ok (fan spins)
HI:
The motherboard is responsible for turnin on the power supply, if the power supply fan is working then the system has started it initinal POST procedure. Try disconnecting any phrephial devices from the unit, starting with the Harddrive DVD Drive Etc. Also you may have a bad video processor on the motherboard, that is causing no video.
Jan 24, 2011 | HP Media Center m7060n PC Desktop
I am replacing the 3 speed fan switch in a ceiling fan. Upon removal of the old switch (due to a cracked/broken screw port), I noted the secific wire and color that was located in each of the four...
Use a continuity tester on old switch.
There will be 1 main wire that connected to power >>> power flows through this wire to the switch and feeds the other 3 wires > each time you click switch, power will flow to one of the other three wires
The do the same test on new switch. Match up wires accordingly.
If you don't have a multimeter, buy inexpensive continuity tester at hardware store.
Continuity tester is basically a flashlight battery and flashlight bulb that lights up when the circuit is closed
Oct 16, 2010 | Gardner Bender Gsw-34 3 Speed Pull Chain...
Hp Pavilion a1620n seems completely dead. Went through a diagnostic and presumed the ps was burnt out. Have since seen the ps light on while all internal cables are unplugged. Can plug all cables in and ps...
No, it indicates a bad power supply.
1) ALL the lights use less than 1 Watt
2) EACH fan uses 2 to 3 Watts
3) A typical processor uses 55 to 125 WATTS.
The base model of the HP Pavilion a1620n Desktop PC, comes with an Intel Pentium D 925
(Operates at a maximum of 3.0GHz)
The Intel Pentium D 925 uses 95 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Presler.22_.28dual_core.2C_65_nm.29
In most cases the inside of the computer is dirty, as well as the inside of the Power Supply, and it's fan.
Heat = Wasted Energy
When the Heatsinks inside a power supply, and it's Fan, (To include the fan blades, fan center hub, and surrounding fan cage), become clogged with gunk, the cooling capacity of the power supply drops tremendously.
Since Heat = Wasted Energy the power supply tries to keep up with the power load demands.
Eventually components inside the power supply fail.
(Usually the Electrolytic Capacitors are the first to go)
The power supply inside a Pavilion a1620n is a common SMPS. Switched Mode Power Supply.
http://en.wikipedia.org/wiki/Switched_mode_power_supply
The style is the common ATX, that is used in over 90 percent of desktop computers. (ATX 12V)
The Wattage is 300 Watts.
Should you like help in finding a replacement power supply that is affordable, and reliable, just state so in an additional comment.
I do advise staying away from the cheap generic models, as they can fail in 6 days to 6 months. ($20 to $25 range)
Jan 18, 2010 | HP Pavilion a1620n (882780664494) PC...
Fans won't start on my compaq evo
I suggest replacing the fans with new fans. Fans do expire and they need to be replaced.
Aug 30, 2017 | Compaq Evo D300s PC Desktop
Noise
reload the operating sysytem
May 24, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Hp pavillion dv6262eu=====dv6000 underneath also ,,,, has been away for repairs 3 times now in 12 months cooling fan runs at half speed whist operating at all times is...
Most likely a power supply problem. Your power supply is probably going bad or not powerful enough for your system. Swap it out for a known working power supply with enough power for your system. Also make sure there is not excessive dust and dirt on the fans.
May 09, 2008 | Computers & Internet
Worked great until last night....
hi put some exhaust fans in the case see if this will help youi had this happen to me a few times add fans and als wellremember you still have your chip set on your mother board they do not have fans and need to be cooled too
Nov 03, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Dell Dimension 2400 PC Desktop Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
