Question about Brother HL-2040 Laser Printer
When a sheet of paper is passed through my Brother 2040 the paper becomes speckled
  • 526 Answers
Its probably 1 of 2 things. either your drum is worn out or your fuser. Most like its the drum. Take your drum out and look at it and see if it looks clean. if it doesnt, it probably is the drum.
another thing you might try, is to make a test print before the paper hits the fuser area and open up the door, this will cause a paper jam, but you can see if you are getting the speckled print before it hits the fuser.
thanks adi
Posted on Apr 20, 2009
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
Brother HL-2040 paper light flashes red (and won't print) with plenty of paper in drawer
Check for a p[aper jam somewher in the route or at the single sheet feed entry
Mar 01, 2011 | Brother HL-2040 Laser Printer
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
Brother 2040 printer. Toner speckles on all the pages.
Take the toner out, and shake it. Make sure you cover the holes or you will make a mess
Everytime I have had spots or streaks this has fixed it for me.
Hope this helps!
P.s. you may want to get a cleaner sheet and run it thought the rolls.
Jan 21, 2009 | Brother HL-2040 Laser Printer
Printer is pulling in too many sheets of paper
change your paper size to a another weight.
Sep 16, 2008 | Brother HL-2040 Laser Printer
Brother 2040 laser printer
You just lightly pull on the sheet of paper from both corners. There is no release valve.
Jul 14, 2008 | Brother HL-2040 Laser Printer
Paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Mar 23, 2008 | Brother HL-2040 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
170 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
