Question about Canon PIXMA MP470 All-in-One Printer
Pixma mp470 the left inside two white plastic
Pixma mp470 the left inside two white plastic rollers don't roll, thus causing paper to load crooked and jams. help me what can I do. It is less than a year old.
  • cbreuerw Apr 21, 2009
    I have no warranty I did not send it in
    Cathy
    Any other solutions to get the rollers moving again
  • 89 Answers
Is it under guarantee if so take it back
please can you rate my help to you
Posted on Apr 20, 2009
Printer only takes paper from one end resulting in a paper jam
I would not have believe this if I have not actually experienced it. Today, my Canon PIXMA MP470 started feeding my paper crooked, to the right where the feed roller is located. Did some research and found numerous people discovered foreign objects inside their printers. Since I had tried numerous other solutions, such as maintenance cleanings from the printer control area. I decided to unplug the printer, turn it upside down and shake it, hoping to dislodge a foreign object. It didn't work. I then took compressed air and sprayed vigorously inside the printer, and tried it again. It didn't work. I then took some card stock (the type used for making greeting cards), put it into the printer and began printing a word processed document - just something to get the card stock to enter the printer. I manually forced it into the printer as it started to print, then after the card stock was about two inches into the printer I manually pulled the card stock back, and THERE IT WAS! My memory card insertion slot protector from my netbook! Thank you Jesus! It is a small piece of black plastic that had fallen from the top of my printer, where I had foolishly placed it while I was using the memory slot in my netbook. Printer works great again! I hope this helps someone!
Jun 15, 2012 | Canon PIXMA MP470 All-in-One Printer
The mp470 printer keeps saying it needs paper when it doesn't and it says the paper is jammed when its not
You will have some paper stuck in it somewhere. I presume you had a jam and removed the paper but it will have probably left some behind. Shine a torch into the print engine and look behind the 4 and 5 white little rollers. Turn the machine around and remove the rear cover and see if any is there. I can almost guarantee some tiny piece of paper is still in there.
Jun 05, 2011 | Canon PIXMA MP470 All-in-One Printer
Message ''The paper is jammed" appears even though there is nothing jammed.
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jun 17, 2010 | Canon PIXMA MP470 All-in-One Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
The paper won't feed through. it did one minute then stopped
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). This, if properly done should do it. Brush especially the rollers etc.
Dec 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper is not loading properly or not at all. The rollers don't catch on to the paper to roll towards the printer heads.
try to clean the rollers ,open the rear access door of the printer clean the rollers there . clean with a lynt free cloth . try this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01609880&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
if that does not work then u need to replace the unit.
Sep 15, 2009 | Canon PIXMA MP470 All-in-One Printer
I get an Error message that states "Paper Output Slot Jammed" and there is no paper or foreign objects in the printer at all!
That happens when the sensor arm is bent or broken, it's inside behind the platen roller, above the white guide plates. If you can see it look for scraps of paper holding it up, if it's bent or broken you need a shop repair.
Aug 25, 2009 | Canon PIXMA MP470 All-in-One Printer
Skewed or crooked paper uptake on Canon Pixma Mx300
Sounds like the roller(s) on the left side is missing or is slick (or split). You should have returned it to the place of purchase when you discovered the problem.
Jul 09, 2009 | Canon PIXMA MP470 All-in-One Printer
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon PIXMA MP470 All-in-One Printer Logo
201 people viewed this question
old marine
old marine
