Question about Dell Dimension 4500 PC Desktop
DELL 4500 as FreeNAS server with three Harddisk (500GB ea)
I own two DELL 4500 Dimensions since many years and I'm mas o meno satisfied with it.
Since I've developed my network also with more media, internetradio, notebooks and last but not least netbooks, I need more space to store all the aols and new datas.
As many user before me I changed one of the DELL 4500 Dimensions into a Server (more detailed: in a FreeNAS server). I remonted the old 80GB WD Harddisk and also the CDRW-Drive. I mounted two 500GB WD Caviar on the Primary ATA Controller as Master and Slave and mounted the DVD ROM Drive on the Secondary ATA Controller as Slave.
Just here all works as it must.
But I would mount an other 500GB WD Caviar in a ICY-DOCK removable cage on the secondary ATA Controller as Master (removable Backup Drive).
Frome here the problem occurs: The BIOS (A04) of the Dell 4500 Dimension does not recognize the Harddrive on the secondary ATA Controller. It jumps over the shadowed letters on the BIOS Shell and on the IDE Tab are only the two drives on the primary ATA Controller shown.
I need a hint and/or a clear answer to the questons:
1. Does it's possible to mount a Harddrive (as explained) on the secondary ATA Controller?
2. If not what is a cheap way do to mount a third Harddrive (as explained) on this system?
3. Why are the two green LED's (Power and Activ) in Front of the Harddrive Drive in every state of the system dark, similar as the Drive is not under power? Maybe because the ROM does not accept the configuration?
My system has 1GB RAM, and runs with 2.0Ghz based on BIOS A04 and under FreeNAS 7 on a Realtek Family Gigabit Ethernet NIC.
Thanks for every suggestions in advance
THINK! that's enough ...
Indalo
  • indalo Apr 20, 2009
    No serious agitation!
    THINK! is better thank fishing!
  • Consilio Apr 23, 2009
    Thanks for your engagement to help me.
    But I try to explain again with other words:
    I own a DELL 4500 Dimension since 2002.
    (Pentium 4, 2.0GHz, 1GB RAM, BIOS Intel A04)
    The 4500 has an Intel Mainboard with one ATA-Combination with twoControllers (Primary + Secondary) and two Connectors each (Master +Slave)
    I use it now as a NAS-Server running on FreeNAS.
    I have installed 2 WD Caviar 500GB instead of orininal WD 120GB.
    I demounted the CD-RW and stay with only one DVD-ROM.
    Thats works fine!
    Now I have one Place free for a third WD Caviar 500GB as Master or Slave on the Secondary Controller together with the DVD-ROM as Master or Slave.
    BUT: The new drive is not recognized on any of the two possibilities Master/Slave on the Secondary Controller. The BIOS shows a greyed Line instead of the drive. The cursor jumps over that Line ... I tried to change the jumper on the drive from (original) "Cable Select" (must have a special cable with 80 lines on the 40 pin connector) to "Master with 2 drives" or "Slave with 2 drives" and the drive on the respective position connected.
    It must be a problem with the BIOS and the Secondary Controller. Of course, I can buy an additional Controllercard (RAID or not) and put the third drive on that. My problem is to know why THIS Solution does not work.
    Thanks for help, if someone knows the reason for that strange situation.
    Indalo
  • 432 Answers
Http://www.openfiler.com/
Open Filer is a better option.
Any chance you can simplify the explanation as to what the issue is.
Posted on Apr 20, 2009
  • Shane Russell
    Shane Russell Apr 20, 2009
    which hard drive does not mount and can you show me which hard drives are attached to what controllers and do the controllers connect via PCI slots ?
  • Shane Russell
    Shane Russell Apr 21, 2009
    any chance you can reply and clarify ? Your controller card ( sata or ide ) should have its own bios that you can go into and configure each drive and you should be able to get it to detect or use it in there assuming you have selected the correct mode for them as you can select RAID or IDE or SATA mode or something like that ( obviously if you set the original drives in a RAID like mode ie mirroring then am not sure if you will just be able to add another hard drive ) and it will have to be treated as a seperate drive.
    The only way around it is to make sure you have at least 3 drives all in all and a backup drive and set it up in RAID 5 ( this will mean you will have to backup all your data that are on the drives currently ) erase all the drives and add the 3rd drive ( preferably get another one as a hot swappable drive ) and configure the 3 drives in a RAID 5 configuration if your controller card supports RAID 5 ( it should specificy on the specs or the manual what type of RAID modes it supports if any )
Por que me corta el wifi en ps3 super slim 500gb y cell y tablet por cortos tiempos
Conexi?n ADSL con filtros de ADSL. ¿Ocurre si alguien llama a la l?nea telef?nica? Podr?a ser defectuoso filtro ADSL cayendo conexi?n a internet.
DSL connection with ADSL Filters. Does it occur if someone rings into phone line ? Could be faulty ADSL Filter dropping connection to internet .
Jul 17, 2014 | NetGear R6300 WiFi Router
How to configure FreeNas
Not sure that I understand your question right, but the non-gui part during the installation only refers to the networking setup. If you want to set up your NAS with a static IP see here.
A general walk through the installation (including photos) is here.
Why do you want to use FreeNAS on ubuntu in the first place? Why not using ubuntu 10.04 server or (my first choice) CentOS 5.x or 6.2 (initial network setup is a little bit tricky on 6.x, but tons of documentation on the net by now). Cent is super stable and you can easily run it without a gui. I use ssh to do whatever I have to do on the box (It's a 8TB backup server.)
Let me know if you have any questions or would like to discuss - I'm happy to help.
Jan 01, 2013 | Computers & Internet
"Harddisk not found" error during
If the computer is telling you that the hard disk is not found, then either it is not hooked up correctly, is set to "disabled" in the BIOS setup, or the hard drive is bad.
Check those things in that order.
Apr 16, 2011 | IBM x3400 Server
Para que sirven las boquillas del modelo 2500 son 5
Son para dar a la presurisadora una salida mas o menos amplia.Si su trabajo es para digamos limpiar un auto entonces utilice una boquilla que la salida sea amplia o si va a lavar la parte del chasis del auto use una boquilla con salida menos amplia.En dode se colocan las boquillas puede encontrar ejemplos de como es la salida del agua. Es decir fina o gruesa.
Vuelva si necesita mas ayuda o Thumbs para mi perfil o de un testimonio de mi ayuda.
Nov 09, 2010 | Karcher 2500 PSI Pressure Washer
I have a dell dimension 4500, I need a compatible internal hard drive for it. Which one to buy?
Check the manufacturer's web-site:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=2684&l=en&s=pub&os=WW1&osl=en&SystemID=DIM_PNT_P4_4500&catid=-1&impid=-1
for your (7-year-old) model, and you'll find a list of PATA (Parallel-ATA) disk-drives recommended by Dell, up to 120GB. Any PATA disk-drive that you can buy, up to 500GB, should also work.
Aug 09, 2010 | Dell Dimension 4500 PC Desktop
What hard drives can I use as replacements?
Call Dell with your Service Tag.
Lifetime support is included on all Dell servers.
Last time I called them I dialed (800) 945-3355
They can sell you the hardware you need and guarantee it will work with your server. They might even be able to help explain the process of installing the drives.
I recommend that you use Acronis' Imaging software (www.acronis.com) so that you can make an exact copy of your data and apply it to the replacement volumes. If you are using a RAID1 array make sure the new array is completely built before applying your image. Builds can take a long time. I created a RAID1 array with 2-320GB disks and it took 3.5 hours to build the RAID1 array.
I hope this helps.
Please vote for my solution if it helps.
Apr 19, 2010 | Dell PowerEdge 2500 Server
Mi pc esta muy lento cambie wind98 por wind xp,necesito mas memoria,cual usar yhasta cuantopuedo ponerle
Se depende como usa su computadora. Si Ud. usala solamente para internet, musica, y email necesita comprar no menos de 512MB a 1GB. Pero si Ud. va a usar su computadora para mas como videos y juegos luego necessita comprar memoria no menos de 1GB a 2GB.
Jul 18, 2009 | Compaq Presario 5000 PC Desktop
Unable to reconnect hard drive.
check  for the connection first try two r three combinations and still if u dont get it then the hard drive is fault
Mar 08, 2009 | Dell Dimension 4500 PC Desktop
Madden 09 ea server problem
ok SET SYSTEM CLOCK back 3 years. i know it sounds stupid, but it resolved my issue. ( FYI, you must be signed out of xbox live to set system clock.)
Dec 18, 2008 | Microsoft Xbox 360 Console
Dimension 4500
ALMOST ALL OF THEM .contact dell support here...http://support.dell.com/.RICHARDM69
Nov 09, 2008 | Dell (KN900) ATX Mid-Tower Case
Dell Dimension 4500 PC Desktop Logo
707 people viewed this question
Alun Cox
