Loses signal intermittently during cable tv viewing, VGA computer viewing, but so far not during DVD play. Today it is every 60 seconds since it has been turned on. It loses signal but then comes back immediately.
This is a 37" Flat HDTV
This problem is probably due to weak signal strength from the cable to the television. Buy a signal amplifier for you cable line in and use another cable out of the amplifier output to your Television input signal source, This should bring up the signal strength for you.You could also have your cable company check the input signal strength to you house or apartment and see if the cable itself needs repairing or replacing.If this does not help with your problem , then you need to have your television tuners signal input circuit tested it may have weakened from age. This may be adjustable in the tuner box, but this is something for a service technician to determine. customer service number for Insignia is 1-877467-4289. Hope this helps you with your problem
Was this helpful?
Yes
No
Popular Solutions for Insignia 37" 720p Flat-Panel
We have 20" LT20s only used 3 weeks out of the year. Sound no picture,its an 2006 fix or throw...
(More)
We have 20" LT20s only used 3 weeks out of the year. Sound no picture,its an 2006 fix or throw away? kind of ashame!Been sitt'in for a year.Olevia LCD
37 in flat screen insigna does not start with remote or side buttons. If power is turned off, there...
(More)
37 in flat screen insigna does not start with remote or side buttons. If power is turned off, there turned back on tv worked properly. This is a daily problem.
