Question about Refrigerators
Water is draining from the evaporator pan out the front of the freezer. I unclugged the drain underneath. Is there anything else I should do for prevention?
The water does not drain out of the evaporator pan. It freezes up and then water runs out the front of the freezer. I unclugged the drain under the pan. Is there anything else I can do?
  • shighley Apr 20, 2009
    Model numebr is jenn-Air jcb2389grs
    The model number is Jenn-Air JCB2389GRS.
    Brigadier General:
  • 8,619 Answers
Hi
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Check for a solid ground wire wrap around the defrost heater and the other end stuck in drain hole. Avoid letting the wire to touch the plastic side of the hole.
Also there are defrost drain kits available for certain manufacturers.
Please tell me the model number of your Refrigerator so that i can provide you with model specific information.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 20, 2009
  • Rylee Smith
    Rylee Smith Apr 20, 2009
    If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
    Please see the picture and check out the drain tube or channel. Also, check for a solid ground wire wrap around the defrost heater and the other end stuck in drain hole. Avoid letting the wire to touch the plastic side of the hole.
    Also check out the water fill lines as they can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
    Thanks
    Rylee
  • Rylee Smith
    Also check for water leaks from the valves and replacxe the valve if necessary. Check to make sure the water tubes are attached properly and are fastened tightly.
    Inspect for holes or cracksin defrost drain pan, and replace the pan if necessary.
    Thanks
    Rylee
I need to stop water from getting on the floor of the freezer?
If your refrigerator is frost-free, water may not be draining into the evaporator pan underneath. The drain tube may be clogged.
Dec 18, 2014 | Refrigerators
Water leaking from front base of freezer
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 29, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaking from bottom front of refrigerator
you don't say whether this is a top mount freezer side by side or what but the most common problem is a blocked defrost drain. you'll have to locate this drain and clean it out. this drain is located underneath evaporator coils in the freezer. every day the refrigerator defrosts and water runs out the drain into a pan in the bottom of the refrigerator where is evaporates.
also make sure you don't have a pin hole or other leak in an ice maker line .
May 27, 2010 | Refrigerators
Water leakage from underneath front of fridge and/or freezer. Ice build up on floor on freezer. Drain pan overflowing? Drain hole appears iced also. Can poke wire down 8" but water isn't draining...
The drain hose is probably clogged with a pea or some kind of food etc. Try pouring boiling water down the hose, or a hair dryer if that doesn't work, or let it warm up until you can pour water down and it comes out into the pan at the bottom. Make sure that the hose is free of dirt etc
Pull out fridge to see the pan, disconnect the POWER..
Oct 31, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leak from underneath the fridge
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 20, 2009 | Kenmore 50522 / 50524 Side by Side...
Leaking from underneath the front periodically. If there is a tray, I cannot find one. Water runs from the bottom every three or four days.
Sep 16, 2009 | Refrigerators
Is a Kenmore Elite Upright Frost-Free Freezer supposed to have water leaking from underneath it? Would this be the water accumulating from the "defrost cycle" on it?
Is the drain pan underneath overflowing? If so the water filter may be clogged and the water leaking past it to the pan. The normal amount of water from the defrost cycle shouldn't fill it up. The condenser fan usually evaporates the water by blowing the warm air on the pan.
There could be a leak because or the defrost drain being stopped up but this usually comes out the bottom of the freezer door.
Sep 16, 2009 | Freezers
Leak!
Hi as well,
With no other source of water for the leak, this has to be your defrost water, and it does sound like the drain to the evaporator pan is clogged.
The pan will be underneath the unit -- should be a panel you can remove along the bottom edge to access the pan.
If you trace the drain from the bottom of the unit back into the fridge, you can find where the water is supposed to drain into the pan. This is apparently clogged.
May 29, 2009 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
386 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
