Question about Kodak Easyshare C813 Digital Camera
Wont turn on
My kodak c813 wont turn on with new batteries
    Brigadier General:
  • 3,917 Answers
There are 2 possibilities for your camera not to start:
1) First please check the batteries . Though you have mentioned its new there would be no harm in trying another working pairs.
2) The biggest mistake done by most are placing the batteries in the correct format. When you open the lid when the battery is placed you would see the + and the -- symbols . Place the batteries in the exact way .
The camera should work unless there is some major damage inside which is not advisable to troubleshoot as you need good knowledge and need to open the camera which is compact on its own.
Is the camera new then please sent it back to Kodak as it would be under warranty.
For a detailed users manual please go through the link provided bellow:
http://www.kodak.com/global/en/service/publications/urg00775toc.jhtml?pq-path=11889
Thanks
Have a nice day.
Posted on Apr 20, 2009
My kodak easyshare C813 wont tern on i havent used it for a wile help
Are the batteries charged? If no replace. Were batteries left inside while the phone was left idle? Try and scrape the terminals. Try switching it on if it'll work.
Dec 06, 2010 | Kodak Easyshare C813 Digital Camera
Kodak easyshare c813 digital camera wont turn on ?
Having gone over a month with no response, I assume it was simply a battery problem.
Jul 16, 2010 | Kodak Easyshare C813 Digital Camera
Wont turn on
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
Dec 31, 2009 | Kodak Easyshare C813 Digital Camera
Wont turn on used new batteries and still wont turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 02, 2009 | Kodak Easyshare C813 Digital Camera
My kodak easyshare c813 camera but it wont turn on
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Sep 26, 2009 | Kodak EasyShare P850 Digital Camera
Kodak camera wont come on even with new batteries
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 15, 2009 | Kodak Easyshare C813 Digital Camera
My kodak easyshare C813 WONT TURN ON!!
After searching and getting the run around, the only solution I've found is to BUY a new camera that IS NOT Kodak!!! I had never had a problem with Kodak until now...I WILL NOT buy this brand ever again!
Apr 03, 2009 | Kodak Easyshare C813 Digital Camera
Camera wont turn on
pull out slightly with a pin the two gold contacts on the battery door
Jan 27, 2009 | Kodak Easyshare C813 Digital Camera
My kodak c813 digital camera will not turn on
I bought this model several months ago and it was working great up until Christmas time.  For some reason it just stopped working.  I couldn't get it to turn on OR sometimes it would turn on after several attempts.  I kept changing the batteries and sometimes that would work, but it was more or less random successes.  I found this link on FixYa : http://wwwuk.kodak.com/global/en/service/batteries/batteryDigCamChart.jhtml?camera=C813
I was using generic batteries (Philips) which I bought in bulk from a discount tech store and these batteries were working in the camera since I bought it.  The batteries were new; just generic.  By coincidence I ended up buying KODAK branded alkaline batteries from the same store.  I replaced the older generic ones with the KODAK batteries and the camera came back to life!  I'll leave it off for a day and see if it turns on tomorrow.
Dec 28, 2008 | Kodak EasyShare C743 Digital Camera
Kodak c813
Ours does the same thing. If you find an answer please let me know!!!! Ours is new and has done this after the 1st day we got it. I took one of the same back to the store thinking there was something wrong with it. Well, this one does the same thing. I've had the new one for 45 days now.
Thanks.
dd
Oct 01, 2008 | Kodak Easyshare C813 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
20 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
