Poulan Pro PRRT850 17 Tine Tiller Logo
A
Anonymous Posted on Sep 29, 2013
Tiller moves but tines will not turn - Poulan Pro PRRT850 17 Tine Tiller
Tiller tines don't turn when I throttle?
Here are some possible causes and solutions:
Belt Issues: If the drive belt is broken or loose, the tines won't turn. Check the belt tension and replace the belt if necessary .
Idler Assembly: If the idler assembly is not properly tensioning the drive belt, the tines won't turn. Adjust the idler assembly or replace it if necessary .
Engagement Cable: If the engagement cable is loose or not tensioned properly, it may need to be tightened or replaced altogether .
Transmission Issues: If there is an issue with the transmission, such as a broken gear, the tines won't turn. Stop using the machine immediately and inspect the transmission .
Since you mentioned that your tiller tines were turning fast after replacing the carburetor and then stopped turning after connecting the throttle cable, it's possible that there is an issue with the engagement cable. You may want to check if it's properly tensioned and connected to ensure that it's not causing any issues How To Fix Tines That Will Not Move - Tiller Repair
Oct 30, 2023 • Garden
Why did my tines stopped working
Hello, Did you notice if the tines moved when you turned the belt pulley to install the new belt? If the tines do not move when you rotate the driven pulley by hand, the worm gear might be stripped. If the tines do move when you rotate the driven pulley by hand, the belt tensioner might not be working properly. It could be as simple as an adjustment.
Aug 28, 2014 • Garden
2helpful
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Tines wont engage on my troy built pony. How can i fix it?
The lever for the tines moves easily? Is there an adjustment on the linkage that may need tightening?
My craftsman rear tine tiller m# 917293202 will not move tines will move but wheels will not
hello, upon inspection of the parts brake down looks like you have broken the drive chain inside of the trans to drive the wheels,there is no mencion if the belt and pulley turns and the wheels don't,did you check the belt and pulley?hope this helps,oh bring it over abd i will repair it,
3helpful
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_d71920e629f739cb
Mar 20, 2011 • Mtd Garden
2helpful
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 • Mtd Garden
2answers
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
