Question about Optimus DS-5080 Digital Camera
I CHARGED THE CAMARA OVER NIGHT AND THE CAMARA IS
I CHARGED THE CAMARA OVER NIGHT (TWICE) AND THE CAMARA IS STILL NOT TURNING ON. HELP PLEASE
  • 1sailboat May 06, 2009
    Thing worked well for a while, now it will not turn on. I have done all the things one might do and still not working - think time for the junk pile. +
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 75 Answers
First off, There is nothing inside the camera that is user, by you, fixable. As simple as it sounds, be sure you are pressing the actual ON/OFF button of the camera. Assured of that and if still NOT working, make sure that the BATTERY is installed correctly, in most cameras and other devices the BATTERY will fit in the device in a designed way to make it idiot proof. Assured of that, make sure that you actually have POWER going to the CHARGER. To make sure that you have power at the outlet you have chosen, plug a lamp into it to determine that the outlet is hot. Assured of that, Now plug your charger in. There should be a light of some color on the charger to indicate that it is doing its job. Either correctly put your BATTERY in the charger or connect your camera to the charger. If your charger has an installed indicator light, it should NOW be illuminated. If it IS so, then your charger most likely works. If NOT illuminated, when it should be, most likely it does not work in which case seek another charger. IF the charger appears to BE working but the BATTERY still does NOT charge, then try another BATTERY (a NEW one). If after eliminating all possible problems that can be addressed by you the user and after TRYING all of the above suggestions, the camera STILL does not work, return it and whine and try for a refund or exchange for one that works or remember that; "All things man made are subject to fail and as if by magic, you have found one that proves it".
Posted on Apr 20, 2009
Please turn camera off and then on again
If your using great battery's then I'd recommend that you have the camera serviced due to it having dust/grit in lens drive unit although I do possess the manual.
What exact model is it ie DMC-FZ5XX ?
Jan 29, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Wont play music
Even though you charged it all night, the battery may not, in fact, have charged. You may need to replace the battery, especially if it is a few years old
Jul 20, 2013 | Mach Speed Eclipse Cl4Bk
I have sony digital camara but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
I dropped my son's camara under my car and it was in the camara case, But it rain all night. When Iwent to get it the case was wet and the camara less is foggie but the camara turn on and off what do I...
Leave it in a dry environment for a few days until everything dries. I'm afraid the camera is permanently damaged if the rain has salt or chemical content. Hopefully it doesn't and it's just a matter of drying out.
Nov 09, 2010 | Cameras
Hi everyone, I just bought my camara last night and added a memory card. The camara now is saying that the internal memory is full, and I have only taken 1 picture? I'm hoping you can help me, please?...
You need to get that one pic out of the internal memory. Here's how...remove your memory card. Go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your memory card and do the "format" thing again to erase and initialize the card. Everything should work properly now.
Apr 18, 2010 | Kodak EASYSHARE M340 Digital Camera
I have a kodak v603 when i try and turn it on i have a red light that flashes under the camara icon on the top left next to the screen. the camara dosent seem to work at all. can any one please help thanks
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 01, 2010 | Kodak EasyShare V603 Digital Camera
Optimus DS-5080 Digital Camera Logo
177 people viewed this question
Top Optimus Cameras Experts
Richard Smart
Jerry Greenberg
Jerry Greenberg
Are you an Optimus Camera Expert? Answer questions, earn points and help others
