Question about Dryers
Back of frigidaire dryer very hot , can I get the back off to see what makes it so hot
    Genius:
  • 1,122 Answers
That's normal there is a big round heating coil connected to the back of the dryer,you have to get in the dryer in the front,unscrew the top and the front panel-mike
Posted on Apr 20, 2009
  • MIKE major Apr 21, 2009
    why did you rate me i was not finished??????mike
  • 101 Answers
SOURCE: frigidaire dryer model #FDE336RES1
The Thermistor is defective, you could get it online.
Posted on Apr 21, 2008
  • 126 Answers
SOURCE: Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Posted on Jan 08, 2009
  • 181 Answers
SOURCE: back of dryer gets extremly hot!!!
put hand at the outlet to see if the warm air is freely coming out. if not there could be a blockage in a pipe inside or the propler fan on the motor has failed.
Posted on May 13, 2009
WonderTech
  • 268 Answers
SOURCE: Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Posted on Aug 12, 2009
MARCLAVORIS
  • 110 Answers
SOURCE: Electric Dryer run too hot
wow, dont get burned, check your ventillation, make sure your vent is not clogged or smashed, if this continues, then change out your thermastat
Posted on Aug 23, 2009
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
Why is my Frigidaire dryer model #FER86600ES0 getting extremely hot on the top and back?
Good afternoon friend, thanks for the post!
I see from your post that your Frigidaire dryer is getting extremely hot on the top and back. Have you checked to make sure that it is getting proper ventilation? I would verify nothing is blocking your dryer from ventilating which could be causing the appliance to heat up. If it continues to heat up I would reach out to a technician to come diagnose and repair your dryer. I hope this is helpful. -Matt
Jul 31, 2014 | Frigidaire Dryers
REPAIR MANUAL FOR 2001 FRIGIDAIRE GLER642AS0
THe back wall of the inside of the drum houses the heating coil. There are insulators that are attached to it. Please check these and also see if there is wear on the seal at the top of that between the drum and the back piece. Also make sure the airflow is good.
Jul 16, 2012 | Frigidaire GLER642A Electric Dryer
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
It sounds like you have a rear bearing bad.
as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
Aug 16, 2009 | Frigidaire FDE647RF Dryer
Back of dryer gets extremly hot!!!
May 12, 2009 | Frigidaire GLER642A Electric Dryer
Frigidaire dryer problem
The vent duct length's sound fine.
Have you confirmed that the heater element is working? You don't mention whether the unit get's hot.
If it get's hot, then suspect the thermostat, or the overtemp stat.
Also, be suspect that users are overloading the dryer.
Also make sure that you feel a strong blast of hot air discharging at the vent end, with the washer/dryer in place.
Check that the vent grills inside of the dryer are clear.
Reply back and I can help you further.
Feb 03, 2009 | Frigidaire Dryers
Back of dryer gets hot
id say your limit switches arent working correctly
Jan 14, 2009 | Frigidaire GLER341A Electric Dryer
Dryers Logo
126 people viewed this question
Top Dryers Experts
