Question about Car Audio & Video
No sound comming from car speakers
System works but no sound.
  • 2 more comments
  • Anonymous Mar 28, 2008
    i have no sound(the inside speakers but can here everything through the sub woffer
  • Anonymous May 07, 2008
    WILL MAKE A SOUND AT ALL I HAVE TWO OF THEM
  • Anonymous Sep 06, 2008
    who can fix if my wires are burned
  • presstone007 May 11, 2010
    what do you hook the blue/white wire up to? idk which wire. oh and with my aftermarket stereo, it had a little cap on it. do i remove this?
My sub is not working i bought a new amp thinking i burnt up my amp. and installed the new amp in my car. my sub still dosent work i bought new rca jacks hooked them up and it amp still no sound. Then i checked all of my wireing it was all correct. i checked the back of my radio it is hooked up correctly but still no sound. i am confused????
Posted on Sep 02, 2008
  • 41 Answers
What kind of car? What kind of system? More details will help me assist you better. If it is an aftermarket in-dash stereo, it sounds like the blue/white wire is not hooked up correctly. This powers up the car's amplifier and lets the sound through.
Posted on Sep 21, 2007
  • 65 Answers
I support thesoundman!
Posted on Sep 24, 2007
No sound from speakers
Possibilities are:
Disconnected cables
Fuse
Short cut from radio to the speakers
You may have to take the radio off and look and see and if is not it, you have to test the speakers as well the lines one by one with a tester
Dec 19, 2013 | 2010 Volkswagen CC
My compaq 620 audio speakers are not working but there is sound when I put on external speakers.
Your internal speaker probably malfunctioned and it needs to be repaired or replaced. The sound card is fine because the external speaker is working.
Feb 28, 2011 | Car Audio & Video
Laptop speakers not working!!!
If you are using Windows Vista.
Step 1: Click on Start then type Sound and select sound from the list.
Step 2: Under Playback Tab please select Speakers and Dual Headphones and click on Set Default.
Step 3: Then click on Apply then sound from your notebook should work.
If these steps do not work then the best option is to re-install the sound driver'.
--Steven Vas (The one)
Jun 09, 2010 | Acer Aspire 5720 Notebook
Sound is not coming from attached speakers I have window xp and ''zoltrixound'' speakers
There can be more than one reason, why the computer can’t play any sounds. These are discussed below:
So, where do you start, when you can’t hear any sounds from your computer?
Before we start with the solutions, did you try the simplest solution first? Reboot or restart the computer. The sounds may just work after a reboot.
Can you hear the Windows startup sounds from the computer? If you can hear the Windows startup sounds, the sound card is working fine. If you can’t hear any startup sounds, enable the System Sounds in the Control Panel, if they are disabled. If you aren’t able to enable the system sounds and they are grayed out, you may need to install the sound driver.
Are you trying to play an audio CD, and not getting any sound? If you can hear the System Sounds, but can’t hear anything from the audio CD, even though your audio player software tells that it’s playing the disc, the problem is most likely with the digital cable that goes from the CD/DVD driver to the sound card (or to the motherboard).
Are the speakers connected to the proper sound port / jack, at the back of the computer? Are they powered ON? External speakers generally have a separate power adapter, which plugs into the wall socket or any other power source. Is the speaker volume control, set to a comfortable level? If not, turn it to the middle position.
If in doubt, test your speakers by connecting them to another sound device like CD/DVD player or a radio/tape player, or any sound source. If you can hear sounds from the speakers, they are fine.
Check that the speaker pin is connected to the green jack on the back of the computer. Also, check that the sound (check speaker icon in the system tray) isn’t muted. Such a simple thing, which can happen accidentally, can confuse some people when they can’t hear sounds from their computers. This can get overlooked because the speaker icon may be lost between many other icons. Click it and un-mute the sound, if it’s muted.
Note: If you can’t see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click “Sound and Audio Devices” and check the box that says “Place volume icon in the taskbar” and click OK.
Try plugging in a pair of headphones in place of the speakers, to check whether you can hear anything. Play a song or music CD or any sound file, which you may have on the computer. If you don’t have one handy, you can run a command to test your sound:
Click the Start button, and then click Run (or Search, in Windows 7 / Vista). Type the following command and then press the Enter key: dxdiag
Click on the ‘Sound’ tab to see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card and the manufacturer, on a piece of paper.
If you can’t see the name of the sound driver, or aren’t able to hear the sound by using the ‘Test DirectSound’ button, or you get an error, the problem may be with the sound driver. If the sound worked sometime ago and now it isn’t working for some reason, the simplest solution for re-installing the sound driver is to do a System Restore. Restore the system to a date that you know, when your sound worked. Check out the following links for a short tutorial on System Restore
Note: Current documents, files and e-mail are not affected by System Restore. If you get an error like “Restoration Incomplete. Your computer cannot be restored“, undo the last action by selecting “Undo my last restoration”.
Here’s a youtube video on how to restore a system with System Restore: http://www.youtube.com/watch?v=mU5yqvye57E
Here are step-by-step tutorials on System Restore:
For Windows XP: http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/ http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/ http://www.vistax64.com/tutorials/76905-system-restore-how.html
For more information about System Restore, visit the following links: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx http://support.microsoft.com/kb/306084http://en.wikipedia.org/wiki/System_Restore http://windows.microsoft.com/en-US/windows-vista/System-Restore-frequently-asked-questions
If System Restore didn’t help or you get a message that System Restore couldn’t be completed, try the following:
Start the Device Manager (Start -> Run -> devmgmt.msc and hit the Enter key). In Device Manager, Click the + sign next to “Sound, video and game controllers”. See that the sound driver that you noted from dxdiag above, is listed.
Doube-click this sound driver. Device Manager should give a status message that the driver is working fine. If the driver isn’t there or if it shows a yellow exclamation mark, shows under other devices, or gives any other kind of status message, reinstall the driver. In any case, it doesn’t harm to uninstall and reinstall the driver.
From this sound driver properties page, you may also click the Troubleshoot button, to open the Sound Troubleshooter in the Windows Help and Support Center.
You can also visit the following link about tips for fixing common sound problems:
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 02, 2010 | Audio Players & Recorders
I have a new PC with Vista installed. BA 745 do not work.
check to make sure you have the speaker icon in the bottom right hand corner. If you do, see if you can move the sound bar up and down. This will verify that you definitely have the right sound drivers installed and they got installed properly.
Make sure you have the speakers connected properly. Here is a setup poster to show you how. Follow this just to be sure
http://supcontent.gateway.com/support.gateway.com/s/SOUND/speakers/7003709/700370935.jpg
Once you verify this and the sound still doesn't work then it could be a problem with the speakers or the sound card or sound chipset (if you have integrated sound on the motherboard).
To verify whether its the sound card or sound chipset on the motherboard or whether it could be the speakers. Put the speakers on another machine that you know has the sound drivers installed and turn up the sound bard in the operating system thru the speaker icon. If you get sound then its a problem with your other computer. If you still dont' get sound then the sound speaker system is bad and would need to be replaced.
Jan 14, 2010 | Boston Acoustics BA745 Computer Speakers
Logitech X-540 connecting to dell dimension 3000 ???
Your problem is you have a 3 channel sound card on your dell and you bought 5 channel speaker system. You can plug the green to green and get 2.1 sound but you will have to by a 5.1 pci sound like in the link below to get the full use of your 5.1 system.
http://www.mikescomputershop.com/asus-xonar-d2pm-sound-card-p-2357.html
Sep 08, 2008 | Logitech X-540 Computer Speakers
Surround wont work
try and download sound softwares from majorgeeks.com.
hope this works.
Jan 05, 2008 | Altec Lansing VS3251 Speaker
Car Audio & Video Logo
697 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
